0003177PartDesignFeaturepublic2021-02-06 06:43
Reporterchrisb Assigned To
PrioritynormalSeverityfeatureReproducibilityhave not tried
Status newResolutionopen
Product Version0.17
Target Version0.20
Summary0003177: Part Design Pad should allow besides "Up to face" something like "Up to plane" as well
DescriptionThe well known pad option "Up to face" should be extended to
- Up to Plane for Datum planes
- Up to edges and Datum lines
- Up to vertices and Datum points
Additional InformationForum discussions:
In the german forum (origin of this feature request)
and in the english forum
2018-08-26 11:23
administrator   ~0011663
Up to Face for Datum planes is fixed with: https://github.com/FreeCAD/FreeCAD/commit/fe2660b4684b51100ccc19c7479d08f7ae507398
normandc
2018-09-02 20:14
manager   ~0011687
Unfortunately, there is a limitation that the datum plane has to be parallel to the sketch plane. If the datum plane is not parallel, this error message pops up:
Pad: Extruding up to a face is only possible if the sketch plane is parallel to it
This appears like a bug, because if there is a solid created first, then a new pad "up to face" works with a slanted datum plane.
In the attached file FC_issue3177_Pad_up_to_face_datum_plane_nc1.fcstd, padding the Body's Sketch up to the slanted datum plane produces the aforementioned error.
But Body001 shows that a sketch attached to an existing pad can be padded to the same datum plane with no such error message.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14498 (Git)
Hash: e381e6b739a6b83b5f476546b64569cfa03a4e3a
Python version: 2.7.15rc1
Qt version: 4.8.7
Locale: French/Canada (fr_CA)
normandc
2018-12-11 02:15
manager   ~0012261
Setting target version to 0.18 to remove the restriction on plane parallel to sketch plane.
normandc
2018-12-31 18:00
manager   ~0012351
Restriction on parallel datum plane was removed by commit ffd980b27e.
As for the rest of the request, I'm not sure. The request asks for "up to edge/vertex". How would that work exactly? How would the pad operation know how to define the ending face, if only a vertex or an edge is selected?
In a commercial CAD I'm familiar with, you can define the extrusion distance with a vertex selected in the 3D view. But it is a different option from the "up to face/plane" option. In this case, the pad ending face is parallel with the sketch plane. Otherwise, the tool does not allow to use an edge.
EDIT: OK I just realized that the request is for multiple vertices and edges.
yorik
2022-03-03 13:55
administrator   ~0016559
This ticket has been migrated to GitHub as issue 5724.
2017-09-06 11:45 chrisb New Issue
2017-09-16 18:04 mlampert Project Path => PartDesign
2018-08-26 11:23 wmayer Note Added: 0011663
2018-09-02 20:14 normandc File Added: FC_issue3177_Pad_up_to_face_datum_plane_nc1.fcstd
2018-09-02 20:14 normandc Note Added: 0011687
2018-09-02 20:14 normandc Note Edited: 0011687
2018-12-11 02:15 normandc Target Version => 0.18
2018-12-11 02:15 normandc Note Added: 0012261
2018-12-31 18:00 normandc Note Added: 0012351
2018-12-31 18:01 normandc Note Edited: 0012351
2019-02-14 21:27 wmayer Target Version 0.18 => 0.19
2021-02-06 06:43 abdullah Target Version => 0.20
