0004348FreeCADBugpublic2022-02-05 02:06
ReporterGerdS Assigned To
Platformi7-4790 + GeForce GTX 750 Ti/PCIOSUbuntuOS Version18.04.4
Target Version0.20
Summary0004348: FreeCad will crash on startup if using X.Org Nouveau display driver
DescriptionIf my PC is running the X.Org Nouveau display driver FreeCad 0.19 will crash either seconds after displaying the main layout or latest if I'll try to create a new document. FreeCad 0.18 runs normally.
If my PC is configured for running the NVIDIA driver-440 metapackage both FreeCad 0.18 and 0.19 will run normally.
So there is an incompatibility between FreeCad 0.19 and the actual X.Org Nouveau display driver, introduced with version 0.19.
FreeCAD InformationOS: Ubuntu 18.04.4 LTS
Version: 0.18.16146 (Git) AppImage
Branch: (HEAD detached at 0.18.4)
Hash: 980bf9060e28555fecd9e3462f68ca74007b70f8
Python version: 3.6.7
Qt version: 5.6.2
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.21125 (Git) AppImage
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Python version: 3.8.2
2022-01-24 18:51
administrator   ~0016275
@GerdS is this still an issue?
GerdS
2022-01-25 16:39
reporter   ~0016298
No, seems to be solved. Meanwhile I have switched both the PC model and updated to Ubuntu 21.10. And there it works with NVidia drivers as should.
2022-02-05 02:06
administrator   ~0016361
Thanks for the follow-up. Closing ticket.
2020-05-21 11:38 GerdS New Issue
2022-01-24 18:51 Kunda1 Note Added: 0016275
2022-01-25 16:39 GerdS Note Added: 0016298
2022-02-05 02:06 Kunda1 Status new => closed
2022-02-05 02:06 Kunda1 Resolution open => no change required
2022-02-05 02:06 Kunda1 Note Added: 0016361
