0004607PartDesignBugpublic2021-12-06 23:13
Reporterdrmacro Assigned Tojnxd
Status closedResolutionfixed
PlatformPCOSLinuxOS VersionUb20.04, Deb10
Product Version0.19
Target Version0.20Fixed in Version0.20
Summary0004607: Can't loft to a Point object in Part Design
DescriptionThis is the same in 0.19 and 0.20
With either a point (toggled to real geometry) in a sketch or a Draft Point you can loft in Part workbench.
(Thus creating a pyramid)
But, error is thrown if attempt is made in Part Design.
Steps To ReproduceSwitch to Part Design WB
Create a sketch, on XY_Plane, with a rectangle, close sketch
Create another sketch, on XY_Plane, offset in Z, create a point
(point is created by default as reference geometry)toggle point to real geometry
Close sketch.
Select sketches and attempt to loft.
Error: Loft: Sections need to have same amount of inner wires as the base section.
This is inconsistent since it works in Part WB.
FreeCAD InformationOS: Ubuntu 20.04.2 LTS (XFCE/ubuntustudio)
Version: 0.20.24498
Build type: Unknown
Hash: 148c528b09c40c302ac5edaff9f2659935094f5c
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
jnxd
2021-11-13 01:04
developer   ~0016026
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=19&t=63697
jnxd
2021-12-06 19:27
developer   ~0016063
Feature added in https://github.com/FreeCAD/FreeCAD/pull/5170
2021-03-26 18:56 drmacro New Issue
2021-11-09 18:21 jnxd Assigned To => jnxd
2021-11-09 18:21 jnxd Status new => assigned
2021-11-13 00:09 jnxd Target Version => 0.20
2021-11-13 01:04 jnxd Note Added: 0016026
2021-12-06 19:27 jnxd Note Added: 0016063
2021-12-06 19:28 jnxd Status assigned => resolved
2021-12-06 19:28 jnxd Resolution open => fixed
2021-12-06 23:13 wmayer Status resolved => closed
2021-12-06 23:13 wmayer Fixed in Version => 0.20
