0004162DraftFeaturepublic2019-10-27 10:27
ReporterKunda1 Assigned Tocarlopav
PrioritylowSeverityfeatureReproducibilityN/A
Status closedResolutionfixed
Summary0004162: Draft Feature: change pointer 'Pick Radius' based on if the user is editing or selecting
DescriptionThe idea is to make the Pick Radius more flexible and intelligent by giving it 2 different options on radius-size based on if the user is at the moment selecting points (which may require a larger pick radius) or editing (which requires more precise Pick Radius).
Additional InformationSource: https://github.com/FreeCAD/FreeCAD/pull/2517#issuecomment-534634341
Forum thread: https://forum.freecad.org/viewtopic.php?f=23&t=40060
TagsDraft, mouse, UI
2019-10-13 16:39
administrator   ~0013755
Assigned to @carlopav
carlopav
2019-10-26 15:57
developer   ~0013789
Fixed with: https://github.com/FreeCAD/FreeCAD/pull/2642/commits
I tried last build (18629 git) and it works good: in Draft preferences, snap and grid, user can find the setting for Draft Edit Pick radius.
2019-10-27 10:27
administrator   ~0013791
Thanks carlopav!
Closing
Related Changesets
FreeCAD: master d87e6324
2019-10-20 14:39:56
carlopav
Committer: yorik Details Diff
[Draft] Edit: pick radius according to user preferences (issue 0004162)
Reference tracker issue 0004162 /view.php?id=4162
Reference topic. https://forum.freecad.org/viewtopic.php?f=23&t=40060.
Changed ui file to insert edit preferences (at the moment inside draft and grid, for the affinity with snap). Created a new draft preference: DraftEditPickRadius.
Affected Issues
0004162
mod - src/Mod/Draft/DraftEdit.py Diff File
mod - src/Mod/Draft/Resources/ui/preferences-draftsnap.ui Diff File
2019-10-12 22:22 Kunda1 New Issue
2019-10-12 22:22 Kunda1 Tag Attached: Draft
2019-10-12 22:22 Kunda1 Tag Attached: mouse
2019-10-12 22:22 Kunda1 Tag Attached: UI
2019-10-12 22:25 Kunda1 Additional Information Updated
2019-10-13 16:39 Kunda1 Assigned To => carlopav
2019-10-13 16:39 Kunda1 Status new => assigned
2019-10-13 16:39 Kunda1 Note Added: 0013755
2019-10-21 19:00 yorik Changeset attached => FreeCAD master d87e6324
2019-10-26 15:57 carlopav Note Added: 0013789
2019-10-27 10:26 Kunda1 Product Version => 0.19
2019-10-27 10:26 Kunda1 Target Version => 0.19
2019-10-27 10:27 Kunda1 Status assigned => closed
2019-10-27 10:27 Kunda1 Resolution open => fixed
2019-10-27 10:27 Kunda1 Fixed in Version => 0.19
2019-10-27 10:27 Kunda1 Note Added: 0013791
