| 0001927 | FreeCAD | Feature | public | 2015-01-17 16:23 | 2016-11-01 15:49 |
| Reporter | shoogen | Assigned To | shoogen | ||
| Summary | 0001927: Abillity to disable all recomputes | ||||
| Description | Currently i need to run FreeCAD in a debugger and use breakpoint in App::Document::recompute() order to prevent FreeCAD from running execute functions due to recomputes. Currently the users can't upload a file with a Feature that crashes FreeCAD. With recomputes disabled the user would be able to save a file without the need to describe all parameters used. Currently i need to step over all the recomputes in the debugger in order be able to use the DRAWEXE exporter. The configuration options, doesn't need any GUI it, would be sufficant to be accessible from python and of course it should not be saved. Maybe it would be desireable that requesting a manual recompute in the GUI would reset the option. But this should not apply to the doc.recompute() python binding, as it used all across python Workbenches (such as Draft) | ||||
| 2015-01-17 16:23 | shoogen | New Issue | |
| 2015-01-28 15:45 | shoogen | Category | Feature => Merge request |
| 2015-01-28 15:45 | shoogen | Target Version | => 0.15 |
| 2015-01-28 16:07 | shoogen | Relationship added | related to 0000491 |
| 2015-03-11 09:04 | shoogen | Target Version | 0.15 => 0.16 |
| 2016-01-19 01:55 | yorik | Target Version | 0.16 => |
| 2016-02-23 14:17 | yorik | Category | Merge request => Feature |
| 2016-11-01 15:49 | shoogen | Status | new => closed |
| 2016-11-01 15:49 | shoogen | Assigned To | => shoogen |
| 2016-11-01 15:49 | shoogen | Resolution | open => fixed |
| 2016-11-01 15:49 | shoogen | Fixed in Version | => 0.17 |
