0003177 | PartDesign | Feature | public | 2017-09-06 11:45 | 2021-02-06 06:43 |
Reporter | chrisb | Assigned To | |||
Priority | normal | Severity | feature | Reproducibility | have not tried |
Status | new | Resolution | open | ||
Product Version | 0.17 | ||||
Target Version | 0.20 | ||||
Summary | 0003177: Part Design Pad should allow besides "Up to face" something like "Up to plane" as well | ||||
Description | The well known pad option "Up to face" should be extended to - Up to Plane for Datum planes - Up to edges and Datum lines - Up to vertices and Datum points | ||||
Additional Information | Forum discussions: In the german forum (origin of this feature request) and in the english forum | ||||
Tags | No tags attached. | ||||
FreeCAD Information | |||||
Up to Face for Datum planes is fixed with: https://github.com/FreeCAD/FreeCAD/commit/fe2660b4684b51100ccc19c7479d08f7ae507398 |
Unfortunately, there is a limitation that the datum plane has to be parallel to the sketch plane. If the datum plane is not parallel, this error message pops up:Pad: Extruding up to a face is only possible if the sketch plane is parallel to itThis appears like a bug, because if there is a solid created first, then a new pad "up to face" works with a slanted datum plane. In the attached file FC_issue3177_Pad_up_to_face_datum_plane_nc1.fcstd, padding the Body's Sketch up to the slanted datum plane produces the aforementioned error. But Body001 shows that a sketch attached to an existing pad can be padded to the same datum plane with no such error message. OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14498 (Git) Build type: Release Branch: master Hash: e381e6b739a6b83b5f476546b64569cfa03a4e3a Python version: 2.7.15rc1 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/Canada (fr_CA) |
Setting target version to 0.18 to remove the restriction on plane parallel to sketch plane. |
Restriction on parallel datum plane was removed by commit ffd980b27e. As for the rest of the request, I'm not sure. The request asks for "up to edge/vertex". How would that work exactly? How would the pad operation know how to define the ending face, if only a vertex or an edge is selected? In a commercial CAD I'm familiar with, you can define the extrusion distance with a vertex selected in the 3D view. But it is a different option from the "up to face/plane" option. In this case, the pad ending face is parallel with the sketch plane. Otherwise, the tool does not allow to use an edge. EDIT: OK I just realized that the request is for multiple vertices and edges. |
This ticket has been migrated to GitHub as issue 5724. |
2017-09-06 11:45 | chrisb | New Issue | |
2017-09-16 18:04 | mlampert | Project | Path => PartDesign |
2018-08-26 11:23 | wmayer | Note Added: 0011663 | |
2018-09-02 20:14 | normandc | File Added: FC_issue3177_Pad_up_to_face_datum_plane_nc1.fcstd | |
2018-09-02 20:14 | normandc | Note Added: 0011687 | |
2018-09-02 20:14 | normandc | Note Edited: 0011687 | |
2018-12-11 02:15 | normandc | Target Version | => 0.18 |
2018-12-11 02:15 | normandc | Note Added: 0012261 | |
2018-12-31 18:00 | normandc | Note Added: 0012351 | |
2018-12-31 18:01 | normandc | Note Edited: 0012351 | |
2019-02-14 21:27 | wmayer | Target Version | 0.18 => 0.19 |
2021-02-06 06:43 | abdullah | Target Version | => 0.20 |
