| 0003817 | Draft | Bug | public | 2019-02-05 00:40 | 2021-02-06 06:45 |
| Reporter | chrisb | Assigned To | yorik | ||
| Summary | 0003817: Draft Preferences "Always show the grid" have no effect | ||||
| Description | From the forum discussion: Draft grid behaviour seems to be in independent of Preferences->Draft->Grid&snapping->"Always show the grid" - Switch to Draft -> grid appears all by itself - Switch to other WB -> grid stays - Switch to and fro another time to switch it off. I can switch the grid off completely in Preferences, but then in the rare occasions where I need it, I cannot switch it on at all. This is what I would like to see: - The behaviour is ok as it is if "Always show the grid" is checked. - if it is not checked: switching to Draft will not show the grid. If the grid is switched on it can stay so even when switching WBs. | ||||
|  | To resume what should be done: If Draft -> Use grid is on and always use grid is on: - Show the grid on entering Draft, keep the grid on leaving Draft If Draft -> Use grid is on and always use grid is off: - Do not show the grid on entering Draft, hide the grid on leaving Draft If Draft -> Use grid is off: - Do not show the grid ever Okay? |
|  | The desired behavior sounds right, but I have a question about the location of the preference. Logically, things that appear in a WB preference should only apply to that WB. So if the grid can apply to FC as a whole, then it seems like it should be in a preference for FC as a whole, not Draft. If it's in a preference for FC as a whole, and it's possible to have it off/on for particular WBs, then the preference should probably be something like "On/off in all" with a further refinement of "except" where one can check the appropriate WBs. |
|  | This ticket has been migrated to GitHub as issue 5878. |
