| 0004267 | PartDesign | Bug | public | 2020-02-15 17:58 | 2021-02-06 06:43 |
| Reporter | uwestoehr | Assigned To | |||
| Summary | 0004267: adding primitives changes body coordinate system | ||||
| Description | - Add 2 primitives, the first one attached to the xy-plane, the second one attached to a face of the first one. Attached is an example file. - now try to mirror the first one along the xy-plane result: you get the error The problem is hereby that the addition of the primitive changes the body coordinate system. Therefore the mirroring is correctly done, but the xy-plane was moved. | ||||
| Additional Information | forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=43395 | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19603 (Git) Build type: Release Branch: master Hash: 62251e3b398ce7d46aba6c84d68da990bfb8b0f9 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| has duplicate | 0004252 | closed | Mirroring of two objects fails. |
|  | @uwestoehr : I changed "global coordinate system" to "body coordinate system" as the GCS roughly can't be altered. However, do you have some evidence that the behavior is linked with coordinate system tampering ? Or is it just rough inference ? I see nothing about it in the forum discussion. ;) Thx. |
|  | This ticket has been migrated to GitHub as issue 6032. |
| 2020-02-15 17:58 | uwestoehr | New Issue | |
| 2020-02-15 17:58 | uwestoehr | File Added: Cube.FCStd | |
| 2020-04-07 16:32 | openBrain | Relationship added | has duplicate 0004252 |
| 2020-04-07 16:35 | openBrain | Summary | adding primitives changes global coordinate system => adding primitives changes body coordinate system |
| 2020-04-07 16:35 | openBrain | Description Updated | |
| 2020-04-07 16:37 | openBrain | Note Added: 0014330 | |
