| Reporter | Fr4nky | Assigned To | chrisb | |
| Status | closed | Resolution | won't fix | |
| Platform | Apple Mac Mini (Early 2009)A1283 | OS | OS X | OS Version | 10.11.6 |
| Product Version | 0.19 | |
| Summary | 0004631: Not compatible with OS X 10.11 El Capitan |
| Description | The FreeCAD Installation Wiki states that Versin 0.19 is compatible with El Capitan 10.11.
https://wiki.freecadweb.org/Download/en
Also on the Downloadpage.
In the forum with other users I found out that this is not the case. It is probably due to a too new QT version.
https://forum.freecadweb.org/viewtopic.php?f=4&t=56953
| Steps To Reproduce | It starts with mounting the DMG, which is not possible under OS X 10.11.
After that, the program does not start. In "Additional Information" I posted my console output once.
Installation via Brew is also not possible. |
| Additional Information | # packages in environment at /Users/runner/work/FreeCAD-AppImage/FreeCAD-AppImage/conda/osx/APP/FreeCAD.app/Contents/Resources:
# Name Version Build Channel
appdirs 1.4.4 pyh9f0ad1d_0 conda-forge
arpack 3.7.0 hff0ca13_2 conda-forge
blas 2.17 openblas conda-forge
blinker 1.4 py_1 conda-forge
boost 1.72.0 py38h89463c3_1 conda-forge
boost-cpp 1.72.0 hd067f63_4 conda-forge
brotlipy 0.7.0 py38h5406a74_1001 conda-forge
bzip2 1.0.8 hc929b4f_4 conda-forge
c-ares 1.17.1 h0d85af4_1 conda-forge
ca-certificates 2020.12.5 h033912b_0 conda-forge
cairo 1.16.0 h4ec454a_1007 conda-forge
calculix 2.17 hd362bd0_2 conda-forge
certifi 2020.12.5 py38h50d1736_1 conda-forge
cffi 1.14.5 py38ha97d567_0 conda-forge
chardet 4.0.0 py38h50d1736_1 conda-forge
coin3d 4.0.0 h6a6324e_1010 conda-forge
cryptography 3.4.6 py38h1fa4640_0 conda-forge
curl 7.75.0 h06286d4_0 conda-forge
cycler 0.10.0 py_2 conda-forge
decorator 4.4.2 py_0 conda-forge
docutils 0.16 py38h50d1736_3 conda-forge
expat 2.2.10 h1c7c35f_0 conda-forge
ezdxf 0.15.2 py38h94cab2e_0 conda-forge
ffmpeg 4.3.1 hb787a4c_2 conda-forge
flann 1.9.1 hed988e5_1008 conda-forge
fontconfig 2.13.1 hd23ceaa_1004 conda-forge
freecad 0.19.1 py38h3eadfbe_0 conda-forge
freecad.asm3 0.10.2 pyhf0f75e1_16 freecad/label/dev
freeimage 3.18.0 h446b61c_7 conda-forge
freetype 2.10.4 h4cff582_1 conda-forge
future 0.18.2 py38h50d1736_3 conda-forge
gettext 0.19.8.1 h7937167_1005 conda-forge
gitdb 4.0.5 pyhd8ed1ab_1 conda-forge
gitpython 3.1.14 pyhd8ed1ab_0 conda-forge
gmp 6.2.1 h2e338ed_0 conda-forge
gmpy2 2.1.0b1 py38haf64e2c_1 conda-forge
gnutls 3.6.13 h756fd2b_1 conda-forge
graphite2 1.3.13 h2e338ed_1001 conda-forge
harfbuzz 2.8.0 h159f659_0 conda-forge
hdf4 4.2.13 h71d84a9_1004 conda-forge
hdf5 1.10.6 nompi_h34ad4e8_1111 conda-forge
icu 68.1 h74dc148_0 conda-forge
idna 2.10 pyh9f0ad1d_0 conda-forge
ifcopenshell v0.6.0 py38he2be11e_3 conda-forge
ilmbase 2.5.5 hfab91a5_0 conda-forge
jasper 1.900.1 h636a363_1006 conda-forge
jinja2 2.11.3 pyh44b312d_0 conda-forge
jpeg 9d hbcb3906_0 conda-forge
jsoncpp 1.8.4 ha1b3eb9_1002 conda-forge
jxrlib 1.1 h35c211d_2 conda-forge
kiwisolver 1.3.1 py38hd9c93a9_1 conda-forge
krb5 1.17.2 h60d9502_0 conda-forge
lame 3.100 h35c211d_1001 conda-forge
lcms2 2.12 h577c468_0 conda-forge
libblas 3.8.0 17_openblas conda-forge
libcblas 3.8.0 17_openblas conda-forge
libclang 11.1.0 default_he082bbe_0 conda-forge
libcurl 7.75.0 h8ef9fac_0 conda-forge
libcxx 11.1.0 habf9029_0 conda-forge
libedit 3.1.20191231 h0678c8f_2 conda-forge
libev 4.33 haf1e3a3_1 conda-forge
libffi 3.3 h046ec9c_2 conda-forge
libgfortran 4.0.0 7_5_0_h1a10cd1_20 conda-forge
libgfortran4 7.5.0 h1a10cd1_20 conda-forge
libglib 2.68.0 hd556434_1 conda-forge
libiconv 1.16 haf1e3a3_0 conda-forge
liblapack 3.8.0 17_openblas conda-forge
liblapacke 3.8.0 17_openblas conda-forge
libllvm11 11.1.0 hd011deb_0 conda-forge
libnetcdf 4.7.4 nompi_h9d8a93f_107 conda-forge
libnghttp2 1.43.0 h07e645a_0 conda-forge
libopenblas 0.3.10 openmp_h63d9170_5 conda-forge
libopencv 4.5.1 py38h3a1a88b_0 conda-forge
libpng 1.6.37 h7cec526_2 conda-forge
libpq 13.1 h052a64a_2 conda-forge
libraw 0.20.2 hefd3b78_1 conda-forge
libredwg 0.11.3876 py38h9cb336a_0 conda-forge
libssh2 1.9.0 h52ee1ee_6 conda-forge
libtiff 4.2.0 h355d032_0 conda-forge
libwebp-base 1.2.0 h0d85af4_2 conda-forge
libxml2 2.9.10 h802ca4f_3 conda-forge
libxslt 1.1.33 h5739fc3_2 conda-forge
llvm-openmp 11.1.0 hda6cdc1_0 conda-forge
lxml 4.6.2 py38h7d97eb6_1 conda-forge
lz4-c 1.9.2 hb1e8313_3 conda-forge
markupsafe 1.1.1 py38h5406a74_3 conda-forge
matplotlib-base 3.3.4 py38hb24f337_0 conda-forge
meshpy 2020.1 py38he9f00de_0 conda-forge
mpc 1.1.0 ha57cd0f_1009 conda-forge
mpfr 4.0.2 h72d8aaf_1 conda-forge
mpmath 1.2.1 pyhd8ed1ab_0 conda-forge
mysql-common 8.0.23 h694c41f_1 conda-forge
mysql-libs 8.0.23 hbeb7981_1 conda-forge
ncurses 6.2 h2e338ed_4 conda-forge
netgen 6.2.1808 py38h65d59e6_1007 conda-forge
nettle 3.6 hedd7734_0 conda-forge
nine 1.1.0 py_0 conda-forge
nspr 4.30 hcd9eead_0 conda-forge
nss 3.47 hc0980d9_0 conda-forge
numpy 1.20.1 py38h64deac9_0 conda-forge
occt 7.4.0 ha4584bc_7 conda-forge
olefile 0.46 pyh9f0ad1d_1 conda-forge
opencamlib 2019.07 py38hb02f84c_3 conda-forge
opencv 4.5.1 py38h50d1736_0 conda-forge
openexr 2.5.5 h7fa7ffa_0 conda-forge
openglider 0.06 pyh9f0ad1d_0 conda-forge
openh264 2.1.1 hfd3ada9_0 conda-forge
openjpeg 2.4.0 h6cbf5cd_0 conda-forge
openssl 1.1.1j hbcf498f_0 conda-forge
pandas 1.2.3 py38h1588c1c_0 conda-forge
parabem 0.3.0 py38hd9c93a9_0 conda-forge
pcl 1.11.1 h7984e4d_1 conda-forge
pcre 8.44 hb1e8313_0 conda-forge
pillow 8.1.2 py38h83525de_0 conda-forge
pip 21.0.1 pyhd8ed1ab_0 conda-forge
pivy 0.6.6 py38h07f26b5_0 conda-forge
pixman 0.40.0 hbcb3906_0 conda-forge
ply 3.11 py_1 conda-forge
py-opencv 4.5.1 py38h9bb44b7_0 conda-forge
pycollada 0.7.1 py_0 conda-forge
pycparser 2.20 pyh9f0ad1d_2 conda-forge
pyexcel-ezodf 0.3.4 py_0 conda-forge
pyopenssl 20.0.1 pyhd8ed1ab_0 conda-forge
pyparsing 2.4.7 pyh9f0ad1d_0 conda-forge
pyside2 5.13.2 py38hc6340e1_4 conda-forge
pysocks 1.7.1 py38h50d1736_3 conda-forge
python 3.8.8 h4e93d89_0_cpython conda-forge
python-dateutil 2.8.1 py_0 conda-forge
python_abi 3.8 1_cp38 conda-forge
pythonocc-core 7.4.1 py38hd3de0cb_0 conda-forge
pytools 2021.2 pyhd8ed1ab_0 conda-forge
pytz 2021.1 pyhd8ed1ab_0 conda-forge
pyyaml 5.4.1 py38h5406a74_0 conda-forge
qhull 2020.2 h940c156_0 conda-forge
qt 5.12.9 h126340a_4 conda-forge
qt.py 1.2.2 py_0 conda-forge
readline 8.0 h0678c8f_2 conda-forge
requests 2.25.1 pyhd3deb0d_0 conda-forge
scipy 1.4.1 py38h38b60c6_3 conda-forge
setuptools 49.6.0 py38h50d1736_3 conda-forge
six 1.15.0 pyh9f0ad1d_0 conda-forge
smesh 8.3.0.3 py38h7dac498_10 conda-forge
smmap 3.0.5 pyh44b312d_0 conda-forge
solvespace 2.4.1 py38h281f984_0 freecad/label/dev
soqt 1.6.0 h02c1c16_0 conda-forge
sqlite 3.34.0 h17101e1_0 conda-forge
svgwrite 1.4.1 pyhd8ed1ab_0 conda-forge
sympy 1.7.1 py38h50d1736_1 conda-forge
tbb 2020.2 h940c156_4 conda-forge
tk 8.6.10 h0419947_1 conda-forge
tornado 6.1 py38h5406a74_1 conda-forge
urllib3 1.26.4 pyhd8ed1ab_0 conda-forge
vtk 8.2.0 py38h3f69d5f_218 conda-forge
wheel 0.36.2 pyhd3deb0d_0 conda-forge
x264 1!161.3030 h35c211d_0 conda-forge
xerces-c 3.2.3 hd3a8c1e_2 conda-forge
xlrd 2.0.1 pyhd8ed1ab_3 conda-forge
xlutils 2.0.0 pyh9f0ad1d_0 conda-forge
xlwt 1.3.0 py_1 conda-forge
xz 5.2.5 haf1e3a3_1 conda-forge
yaml 0.2.5 haf1e3a3_0 conda-forge
zlib 1.2.11 h7795811_1010 conda-forge
zstd 1.4.8 h62961b2_0 conda-forge
Sorry, "freecad" can not be run on this version of macOS. Qt requires macOS 10.12.0 or later, you have macOS 10.11.6.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
| Tags | No tags attached. |
| FreeCAD Information | <!--ATTENTION:
COMPLETELY ERASE THIS AFTER PASTING YOUR
Help > About FreeCAD > Copy to clipboard
NOTE: just the snippet alone will do without anything else included.
The ticket will not be submitted without it.
