| 0004651 | Part | Bug | public | 2021-05-01 11:51 | 2021-05-13 16:59 |
| Reporter | Daniele75 | Assigned To | |||
| OS | Windows 10 Home | OS Version | 20H2 | ||
| Summary | 0004651: Problem in using the sweep function | ||||
| Description | I found a bug when making springs that occurs in version 19, while up to 18 it worked smoothly. | ||||
| Steps To Reproduce | 1° new file 2° goto "Part" ambient 3° creates parametric geometric primitives 4° Propeller 5° set dimension: pitch 0,75 ; height 3mm ; radius 1,3mm 6° Create Propeller ( Ok ) 7° goto "Sketcher" ambient 8° Create new Sketcher 9° Select XZ floor 10° Create circle 11° Set constraints... radius 0,2mm ; height from y axis 0mm ; distance from x axis 1,3mm ( same than radius of propeller ) 12° close 13° goto "Part" ambient 14° select Sweep utilities 15° Select Sketch from list available profiles 16° bring to selected profiles 17° select all the propeller in the draw ( black to green color ) 18° check create solid + frenet 19° OK the sweep obtained is corrupted. | ||||
| FreeCAD Information | I discovered the problem as initially I had version 18 installed on one pc, then on another I installed version 19. Seeing the problem with the 19 I tried both versions on the same pc, first replacing it with the previous one then trying to use them both in the same pc at the same time. | ||||
|  | @Daniele75 : please address your issue according our reporting guidelines by opening a new topic on our forum. Thx |
|  | This ticket has been migrated to GitHub as issue 6211. |
