| 0004769 | Path | Bug | public | 2021-10-18 20:36 | 2021-10-18 20:36 |
| Summary | 0004769: Changing TC with same tool number but different spindle speed doesn't produce correct gcode | ||||
| Description | The user may desire to run the same tool at different feeds and speeds within a job.  This is achieved by creating two tool controllers and using the same tool number for both.  During post processing, the tool number of the new tool is compared to the old one and if they are the same, the tool change code is suppressed.  This is correct behavior.  However, if the spindle speed changes, an M3 (or M4) with the new spindle speed should be emitted and it is not. | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=15&t=62762&start=10 | ||||
| FreeCAD Information | All versions and platforms are affected | ||||
