| 0004781 | FreeCAD | Bug | public | 2021-11-08 14:41 | 2021-11-08 14:42 |
| Reporter | vectronic | Assigned To | |||
| Platform | Intel | OS | MacOS | OS Version | 11.6 |
| Summary | 0004781: Issue with Linear Pattern in the Part Design workbench when replicating an Additive Pipe based on an elliptical path. | ||||
| Description | I am trying to use Linear Pattern to duplicate a flange on a pin. The flange is created using an additive pipe which uses a path sketch involving an ellipse. This doesn't work. I have queried in the forum to see if this was: - a known bug (doesn't seem to be) - more experienced users can get it to work (they can't) - more experienced users thought it might be a bug (they do) Forum link: https://forum.freecadweb.org/viewtopic.php?f=3&t=63409 I have taken my sample from the forum, improved it based on their feedback and simplified it a lot more. I have also included a comparison of using a circle (instead of an ellipse) for the additive pipe path and this seems to work fine with the linear pattern feature. In the linear-pattern-attempt-1.FCStd you will see:
In the linear-pattern-attempt-2.FCStd you will see:
| Steps To Reproduce | Open the linear-pattern-attempt-1.FCStd file and observe that: - the linear pattern using the feature of an additive pipe based on a circle path sketch IS rendered. - the linear pattern using the feature of an additive pipe based on an ellipse path sketch IS NOT rendered. OR Open the linear-pattern-attempt-2.FCStd file and observe that the linear pattern including both additive pipes is rendered incorrectly.sketch is not rendered. | ||||
| Additional Information | Screenshots: https://f001.backblazeb2.com/file/vectronic-public/freecad/screenshots.zip Sample models: https://f001.backblazeb2.com/file/vectronic-public/freecad/models.zip | ||||
| Tags | Part Design | ||||
| FreeCAD Information | OS: macOS 10.16 Word size of FreeCAD: 64-bit Version: 0.20.Unknown Build type: Release Python version: 3.9.7 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.3 Locale: C/Default (C) | ||||
