0004787ExpressionsBugpublic2021-11-12 11:47
ReporterRoy_043 Assigned To
Status newResolutionopen
Product Version0.20
Summary0004787: Labels in expressions not updated correctly when Std_MergeProjects is used.
DescriptionWhen merging the same project more than once, Labels used in expressions are only updated if they match the Name of the object they refer to.
Steps To Reproduce
  1. Open a new document.
  2. Use Std_MergeProjects to merge the attached file twice.
  3. The expression for the Radius of Cylinder001 is
    <<Cube>>.Width
    , it should be
    <<Cube001>>.Width
  4. The expression for the Height of Cylinder001 has been correctly updated to
    <<BoxFromCode001>>.Height
Additional InformationRelated forum pots:
https://forum.freecadweb.org/viewtopic.php?f=3&t=28511
https://forum.freecadweb.org/viewtopic.php?f=3&t=63285
FreeCAD InformationOS: Windows 8.1 (6.3)
Version: 0.20.26306 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
Locale: Dutch/Netherlands (nl_NL)
Roy_043
2021-11-12 11:47
reporter
box.FCStd (9,967 bytes)
yorik
2022-03-03 13:55
administrator   ~0017115
This ticket has been migrated to GitHub as issue 6284.
2021-11-12 11:47 Roy_043 New Issue
2021-11-12 11:47 Roy_043 File Added: box.FCStd
