| 0004812 | FreeCAD | Patch | public | 2021-12-25 12:54 | 2021-12-25 13:14 |
| Reporter | Frank_Schruefer | Assigned To | |||
| Summary | 0004812: Using custom threads in fasteners ScrewTab generates variable used before assigned exception | ||||
| Description | Hy, I have a path for a trivial bug in the fasteners workbench code. Without it the use of custom thread diameters and pitch won't work. | ||||
| Steps To Reproduce | -Choose fasteners Workbench -Create 'Add threaded Rod for tapping holes' -Change 'diameter' to 'Custom' -Change 'diameter Custom' and 'pitch Custom' | ||||
| Additional Information | Patch created via: stone@merlin:~/.local/share> diff -c FreeCAD/Mod/fasteners/screw_maker.py.orig FreeCAD/Mod/fasteners/screw_maker.py Diff output: *** FreeCAD/Mod/fasteners/screw_maker.py.orig 2021-12-22 00:43:13.164645112 +0100 --- FreeCAD/Mod/fasteners/screw_maker.py 2021-12-22 00:44:23.605517538 +0100 *************** *** 3792,3798 **** else: # custom pitch and diameter P = customPitch if self.sm3DPrintMode: ! dia = self.smNutThrScaleA * dia + self.smNutThrScaleB else: dia = customDia residue, turns = math.modf((l)/P) --- 3792,3798 ---- else: # custom pitch and diameter P = customPitch if self.sm3DPrintMode: ! dia = self.smNutThrScaleA * customDia + self.smNutThrScaleB else: dia = customDia residue, turns = math.modf((l)/P) *************** *** 3831,3837 **** else: # custom pitch and diameter P = customPitch if self.sm3DPrintMode: ! dia = self.smScrewThrScaleA * dia + self.smScrewThrScaleB else: dia = customDia if self.rThread: --- 3831,3837 ---- else: # custom pitch and diameter P = customPitch if self.sm3DPrintMode: ! dia = self.smScrewThrScaleA * customDia + self.smScrewThrScaleB else: dia = customDia if self.rThread: *************** *** 3870,3876 **** else: # custom pitch and diameter P = customPitch if self.sm3DPrintMode: ! dia = self.smScrewThrScaleA * dia + self.smScrewThrScaleB else: dia = customDia dia = dia*1.01 --- 3870,3876 ---- else: # custom pitch and diameter P = customPitch if self.sm3DPrintMode: ! dia = self.smScrewThrScaleA * customDia + self.smScrewThrScaleB else: dia = customDia dia = dia*1.01 | ||||
| FreeCAD Information | OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5) Word size of FreeCAD: 64-bit Version: 0.20.26651 (Git) AppImage Build type: Release Branch: (HEAD detached at d357d52) Hash: d357d524d97db884b9bb562415e6b6d782ec02b4 Python version: 3.9.7 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.3 Locale: German/Germany (de_DE) | ||||
P.S.: Forgot to mention that in order to reproduce the bug the 'Thread generation' option in the fasteners workbench settings must be set to '3D printer compatible'. |
This ticket has been migrated to GitHub as issue 6300. |
| 2021-12-25 12:54 | Frank_Schruefer | New Issue | |
| 2021-12-25 13:14 | Frank_Schruefer | Note Added: 0016130 |
