| 0000100 | FreeCAD | Bug | public | 2010-05-22 22:38 | 2010-08-27 07:17 |
| Reporter | yorik | Assigned To | |||
| Target Version | 0.11 | ||||
| Summary | 0000100: Drawing module - mouse operations don't work | ||||
| Description | A couple of mouse operations (zooming around mouse cursor, panning, etc) seem to be implemented in the Drawing module (Drawing/App/DrawingView.cpp) but it looks like none are working here: - pressing/dragging middle mouse button does nothing (should be panning) - zooming with mouse wheel zooms from upper left corner (should be from mouse cursor) Can any of you have a look? Other point I'm wondering: Shouldn't we set the drawing sheet background as white by default (instead of Qt Base color, which can be non white)? drawing module is made almost only for printing, so it would make sense IMHO... What do you think? | ||||
Unfortunately its not a bug - its just not implemented jet... ;) |
Oh sorry... I should have looked better. I'll do a commit with the white page background okay? If anything is weird we roll back to normal... Other thing I'd like to do: add a couple of properties to the page object: A hint scale and a hint offset. Those properties normally won't be used by the page itself, but they would be useful so that scripts can read them, and know what is the default scale and offsets expected on a given page. So you can add objects to a page later without always setting the scale manually... Ok for you if I do that? |
Ok, I did it without your opinion... it's in rev 3185. If there is anything you don't like don't hesitate to revert. |
Ahhh, I didnt see your notes! I will take a look but im confident you make a good job. You slowly get a C++ hacker - don't you? ;) |
The drawing view has been reworked using Qt's QGraphicsView class which does already some of the mouse operations. However, for dragging it uses the left mouse button instead of the middle one. Done in rev. 3465 ff. |
| 2010-05-22 22:38 | yorik | New Issue | |
| 2010-05-27 12:21 |
Note Added: 0000226 | |
| 2010-05-27 12:22 |
Status | new => assigned |
| 2010-05-27 12:22 |
Assigned To | => Jriegel |
| 2010-05-27 12:44 | yorik | Note Added: 0000230 | |
| 2010-05-27 19:21 | yorik | Note Added: 0000231 | |
| 2010-06-09 11:14 |
Note Added: 0000242 | |
| 2010-06-29 13:24 |
Target Version | => 0.11 |
| 2010-08-27 07:17 | wmayer | Note Added: 0000305 | |
| 2010-08-27 07:17 | wmayer | Status | assigned => closed |
| 2010-08-27 07:17 | wmayer | Resolution | open => fixed |
