| 0001014 | Sketcher | Bug | public | 2013-02-17 17:46 | 2015-01-07 16:33 |
| Reporter | axre0433 | Assigned To | jmaustpc | ||
| Summary | 0001014: Adding object to sketch already used in sweep causes segmentation fault | ||||
| Description | Using FreeCAD 0.13 and the attached file it is possible to trigger a segmentation fault by: * Opening Sketch003 for editing, and * trying to add some object (arc, rectangle, circle, ...) to it. Result: Adding face failed on Face3. Omitted segmentation fault Named sketch is already used in both a sweep and fusion operation. | ||||
| Additional Information | OS: Ubuntu 12.04.2 LTS Platform: 32-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
2013-02-17 17:46
This is now very old, the file does not crash the FreeCAD below... OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4435 (Git) Branch: master Hash: f24e216db4fb923b2571ad9d856f934e81bec797 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1.oce-0.17-dev |
This now very old issue can not be reproduced with current software. |
| 2013-02-17 17:46 | axre0433 | New Issue | |
| 2013-02-17 17:46 | axre0433 | File Added: Kartusche3_normandc-arc-sweep-draft-faces.fcstd | |
| 2015-01-07 16:32 | jmaustpc | Note Added: 0005562 | |
| 2015-01-07 16:33 | jmaustpc | Note Added: 0005563 | |
| 2015-01-07 16:33 | jmaustpc | Status | new => closed |
| 2015-01-07 16:33 | jmaustpc | Assigned To | => jmaustpc |
| 2015-01-07 16:33 | jmaustpc | Resolution | open => no change required |
