| 0001017 | FreeCAD | Bug | public | 2013-02-18 13:26 | 2014-09-16 17:30 |
| Reporter | hobbes1069 | Assigned To | yorik | ||
| Summary | 0001017: Fixes to Start Page | ||||
| Description | When I first load a part file with the start page still open and change the workbench to Complete the start page tab is shown. This only seems to happen the first time. Every time I select a sketch object and click the "create or edit sketch" button, the start page tab is show. I think what's actually going on is when the windows is refreshed, the tab window gets reset to whichever tab is first... | ||||
I'll look at it, I thik probably the startpage is still the Active Document"... maybe we can/should remove the startpage tab once an action is performed... |
Other things to fix: - Remove the videos section - Give a bit of refresh to the general styling for 0.14 - Open external links in an external browser - Fix links right-click menu option "Open in new window" |
Another issue, don't know if it happens for you too (0.14 2370Git on Windows 7): When opening Freecad and the start page the prograssbar goes only to 50%. If you use right mouse click->cancel, it goes to 100%. If you then do right mouse click->reload it opens the download manager and downloads hundrets of files without ever stoping. |
For me all seems normal... The progress bar goes up to 100%, and clicking "reload" reloads the page normally... |
I now fixed several issues and made a bit of a visual upgrade, two problems are still there: 1) Right-click -> Open in a new window is still there and should be reimplemented to open links with QDesktopServices::openUrl(), but I couldn't find out how to do that and pass it the url ( suggested in http://stackoverflow.com/questions/3327222/how-to-edit-qtwebkits-right-click-context-menu-in-qt-creator ) 2) Opening FreeCAD -> Switching to the Start WB -> Opening a file -> Switching to the complete WB still changes the active tab to the start page. This happens only with the Complete WB, not the others. So I guess the problem is with the Complete WB, not the Start WB. But I couldn't find anything different there... |
> 2) ... This might be related to the use of this combo box which at this time has the focus and gets removed during the switch and this might cause Qt to give the 1st MDI view the focus. If you switch by menu then this doesn't happen. Another big problem with the combo box is that with recent Qt versions it stays when switching to the complete workbench. This even happens when switching by menu. So, the combo box must be replaced ASAP. With older Qt versions I never had this problem but now I do. |
I think Jürgen has been talking about replacing that combobox with a menu (which I also find a good idea). Maybe this would be a good time to rethink about the complete WB too, if we still need it, etc... |
One interesting feature to have on the start page, would be a kind of "there is a new version available!" message... That would check a particular location (for ex. a wiki page) and get what is the latest build available for you, given your OS and current version (stable/development). This certainly would deserve further thinking, though. |
FreeCAD: master 66f6dc62 2014-03-03 21:01:18 Details Diff |
Start: Improvements to the Start page - relates to 0001017 * Removed the videos section * Added descriptions for feed links * New cleaner look * Colors taken from the system * Feed links open in an external browser |
Affected Issues 0001017 |
| mod - src/Mod/Start/StartPage/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Start/StartPage/StartPage.py | Diff File | ||
| mod - src/Mod/Start/StartPage/blank.png | Diff File | ||
| add - src/Mod/Start/StartPage/freecad-doc.png | Diff File | ||
| mod - src/Mod/Web/Gui/BrowserView.cpp | Diff File | ||
FreeCAD: master e99daa44 2014-03-05 15:53:09 Details Diff |
Start: Fixed utf8 bug |
FreeCAD: master 71bc500a 2014-03-08 16:37:24 Details Diff |
Start: more improvements to the start page |
FreeCAD: master f9c0abc1 2014-03-08 17:42:18 Details Diff |
Start: better scrolling of the description box - issue 0001017 |
FreeCAD: master bf98d138 2014-03-09 18:07:58 Details Diff |
Start: Fixes in css - issue 0001017 |
FreeCAD: master 302fcde1 2014-09-16 17:58:07 Details Diff |
Startpage now checks for new versions - issue 0001017 After loading, the startpage now checks for http://www.freecadweb.org/version.php and compares with current version, and displays a message accordingly. |
FreeCAD: master 9f7956b1 2014-09-16 19:16:44 Details Diff |
Web: Added an Open Link In External Browser context menu option - fixes 0001017 |
| mod - src/Mod/Web/Gui/BrowserView.h | Diff File | ||
| 2013-02-18 13:26 | hobbes1069 | New Issue | |
| 2013-02-18 15:10 | yorik | Status | new => assigned |
| 2013-02-18 15:10 | yorik | Assigned To | => yorik |
| 2013-02-18 15:11 | yorik | Note Added: 0002919 | |
| 2014-02-28 18:43 | yorik | Summary | 0.13: Certain actions with start page tab still open changes tab to start page. => Fixes to Start Page |
| 2014-02-28 18:44 | yorik | Note Added: 0004334 | |
| 2014-03-01 15:54 | yorik | Note Edited: 0004334 | |
| 2014-03-03 06:36 | ickby | Note Added: 0004359 | |
| 2014-03-03 15:24 | yorik | Note Added: 0004365 | |
| 2014-03-03 20:17 | yorik | Note Added: 0004367 | |
| 2014-03-03 20:44 | yorik | Changeset attached | => FreeCAD Master master 66f6dc62 |
| 2014-03-05 16:07 | yorik | Changeset attached | => FreeCAD Master master e99daa44 |
| 2014-03-08 16:32 | yorik | Changeset attached | => FreeCAD Master master 71bc500a |
| 2014-03-08 16:59 | yorik | Changeset attached | => FreeCAD Master master f9c0abc1 |
| 2014-03-08 19:21 | wmayer | Note Added: 0004392 | |
| 2014-03-09 17:29 | yorik | Changeset attached | => FreeCAD Master master bf98d138 |
| 2014-03-09 21:20 | yorik | Note Added: 0004400 | |
| 2014-05-03 16:11 | yorik | Note Added: 0004612 | |
| 2014-07-06 15:27 | yorik | Target Version | => 0.15 |
| 2014-09-16 16:20 | yorik | Changeset attached | => FreeCAD Master master 302fcde1 |
| 2014-09-16 17:30 | yorik | Changeset attached | => FreeCAD Master master 9f7956b1 |
| 2014-09-16 17:30 | yorik | Status | assigned => closed |
| 2014-09-16 17:30 | yorik | Resolution | open => fixed |
