0001018FreeCADBugpublic2013-03-03 11:28
Reporterwmayer Assigned Towmayer
Fixed in Version0.14
Summary0001018: Possible inconsistencies between Euler angles, quaternion and matrix
Descriptionhttps://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=9&t=3613
shoogen
2013-02-19 08:53
developer   ~0002921
I think that the not common order of elements in the quaternion (x,y,z,w) should be documented for the python interface as well. Because it differs from most textbooks where the first element is real/angular.
As well it might be overlooked from the python interface that the eulerian angles are not just only interpreted in the order yaw,pitch and roll but also have to be given in that order.
Despite those uncertainties in the documentation I can not understand/reproduce the problem.
2013-02-19 14:14
administrator   ~0002922
Everything is fine.
shoogen
2013-02-20 09:28
developer   ~0002924
why has it been reopened?
2013-02-20 18:19
administrator   ~0002926
Because of your comments about the (x,y,z,w) notation. So, the documentation of this class needs to be extended.
2013-03-03 11:28
administrator   ~0002959
git show 76a7e0f
2013-02-18 20:24 wmayer New Issue
2013-02-19 08:53 shoogen Note Added: 0002921
2013-02-19 14:14 wmayer Note Added: 0002922
2013-02-19 14:14 wmayer Status new => closed
2013-02-19 14:14 wmayer Resolution open => no change required
2013-02-19 14:14 wmayer Fixed in Version => 0.14
2013-02-19 18:18 wmayer Assigned To => wmayer
2013-02-19 18:18 wmayer Status closed => acknowledged
2013-02-20 09:28 shoogen Note Added: 0002924
2013-02-20 18:19 wmayer Note Added: 0002926
2013-03-03 11:28 wmayer Note Added: 0002959
2013-03-03 11:28 wmayer Status acknowledged => closed
