| 0001028 | FreeCAD | Bug | public | 2013-02-25 16:17 | 2013-12-06 00:45 |
| Reporter | krys_barry | Assigned To | wmayer | ||
| Summary | 0001028: Main window resized when a document is opened | ||||
| Description | Each time a document is opened the main window shrinks, I suspect to the size of the drawing pane prior to opening the new document. | ||||
Is this behaviour still happening with a recent 0.13 version? If yes, please tell your OS version and paste the contents of the FreeCAD help->About panel |
yes, happens with mine and has been doing this for a long time in 0.12 release too. Using GIT. Kubuntu 13.04 KDE 4.10 using KWin I have a feeling the MDI View has a hardcoded size or has an incorrect size hinting. |
Is it the MDIView or the MainWindow. Anyway can you add the method resizeEvent(QResizeEvent*) to where it happens and then set a breakpoint? Maybe in the stack trace you can see where the event comes from. |
| 2013-02-25 16:17 | krys_barry | New Issue | |
| 2013-04-23 22:03 | yorik | Note Added: 0003108 | |
| 2013-04-23 22:03 | yorik | Status | new => feedback |
| 2013-05-14 04:08 | wmayer | Relationship added | duplicate of 0000282 |
| 2013-05-15 06:00 | mrlukeparry | Note Added: 0003157 | |
| 2013-05-15 11:40 | wmayer | Note Added: 0003159 | |
| 2013-12-06 00:45 | wmayer | Changeset attached | => FreeCAD Master master c771c2ed |
| 2013-12-06 00:45 | wmayer | Assigned To | => wmayer |
| 2013-12-06 00:45 | wmayer | Status | feedback => closed |
| 2013-12-06 00:45 | wmayer | Resolution | open => fixed |
