| 0001037 | FreeCAD | Bug | public | 2013-03-01 09:44 | 2013-07-01 15:33 |
| Reporter | vdhproducts | Assigned To | |||
| Summary | 0001037: Can not import/open some step files | ||||
| Description | Can't open or import some step files | ||||
| Additional Information | Using FreeCAD_0.13.1828_x86_setup.msi | ||||
2013-03-01 09:44
I have no problem importing this STEP file either from File --> Import or Part --> Import CAD menu. See attached FCStd file. OS: Ubuntu 12.04.2 LTS Platform: 64-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 |
2013-03-08 03:44
The attached files can now be imported (there are "+" sign between the filename words). Ït seems that the filename causes the problem(DOS??). When I rename the files there is no problem anymore. When I open the original file Freecad "says" "Reading STEP file" and the progress bar stays on 100% and the program is no longer responding. |
I can't confirm this behaviour. Feel free to reopen if it still doesn't work. |
| 2013-03-01 09:44 | vdhproducts | New Issue | |
| 2013-03-01 09:44 | vdhproducts | File Added: 130228 VDH - MC3 - Ring R01.stp | |
| 2013-03-08 03:44 | normandc | Note Added: 0002967 | |
| 2013-03-08 03:44 | normandc | File Added: 130228+VDH+-+MC3+-+Ring+R01.fcstd | |
| 2013-03-08 07:02 | vdhproducts | Note Added: 0002969 | |
| 2013-07-01 15:33 | wmayer | Note Added: 0003318 | |
| 2013-07-01 15:33 | wmayer | Status | new => closed |
| 2013-07-01 15:33 | wmayer | Resolution | open => no change required |
| 2013-07-01 15:33 | wmayer | Fixed in Version | => 0.14 |
