| 0001042 | FreeCAD | Feature | public | 2013-03-02 15:42 | 2013-04-11 15:20 |
| Reporter | jdbrandmeyer | Assigned To | yorik | ||
| Summary | 0001042: Feature Request:: DXF Export in XY plane | ||||
| Description | If a surface which is being exported does not lay in the XY plane, then the resulting DXF file is basically useless by third-party 2D applications. Can such exports be automatically rotated into the XY plane? | ||||
| Additional Information | 64-bit Windows, 32-bit application OS: Windows 7 Platform: 32-bit Version: 0.13.1828 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.3.0 | ||||
2013-03-02 15:42
Yes, that is possible to implement, a routine should be implemented before exporting that reorient all points on a certain workplane... I cannot promise you when I can do it, though. |
Done with 6dbf66b There is now an option in Draft preferences to project exported objects along the current view direction. |
| 2013-03-02 15:42 | jdbrandmeyer | New Issue | |
| 2013-03-02 15:42 | jdbrandmeyer | File Added: StatorLamination.dxf | |
| 2013-03-02 21:51 | yorik | Note Added: 0002956 | |
| 2013-03-02 21:51 | yorik | Status | new => assigned |
| 2013-03-02 21:51 | yorik | Assigned To | => yorik |
| 2013-04-11 15:20 | yorik | Note Added: 0003059 | |
| 2013-04-11 15:20 | yorik | Status | assigned => closed |
| 2013-04-11 15:20 | yorik | Resolution | open => fixed |
| 2013-04-11 15:20 | yorik | Fixed in Version | => 0.14 |
