| 0001064 | FreeCAD | Bug | public | 2013-03-24 19:38 | 2013-03-30 12:48 |
| Reporter | eirc2thered | Assigned To | wmayer | ||
| Summary | 0001064: Crash occurs in version 0.13 when trying to use alignment tool | ||||
| Description | using two step files with the alignment tool causes the program to crash. FreeCAD exited with code 0 in QT creator | ||||
2013-03-24 20:11
I added the backtrace. This is not related to step files. this can be reproduced with a new document and 2 blocks. |
git show 7c3e6fa This error report is misleading because it claims it happens in v0.13 which is definitely wrong. The bug has been introduced with the merge of the dev-assembly branch that was done after v0.13 was out. |
| 2013-03-24 19:38 | eirc2thered | New Issue | |
| 2013-03-24 20:11 | tanderson69 | File Added: alignmentBackTrace.txt | |
| 2013-03-24 20:12 | tanderson69 | Note Added: 0003004 | |
| 2013-03-30 12:45 | wmayer | Status | new => assigned |
| 2013-03-30 12:45 | wmayer | Assigned To | => wmayer |
| 2013-03-30 12:48 | wmayer | Note Added: 0003016 | |
| 2013-03-30 12:48 | wmayer | Status | assigned => closed |
| 2013-03-30 12:48 | wmayer | Resolution | open => fixed |
| 2013-03-30 12:48 | wmayer | Fixed in Version | => 0.14 |
| 2013-03-30 12:52 | wmayer | Note Edited: 0003016 |
