| 0001065 | FreeCAD | Merge request | public | 2013-03-25 07:35 | 2013-03-25 13:33 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Priority | normal | Severity | tweak | Reproducibility | N/A |
| Platform | all | OS | all | ||
| Target Version | trunk | Fixed in Version | 0.14 | ||
| Summary | 0001065: Tree icons for Part Ruled surface, Part Export and some other fixes | ||||
| Description | Hi Yorik If its OK with you, could you please commit this to master? https://github.com/jmaustpc/FreeCAD_sf_master/commits/mymodsicons4_ruledsurface_tree_icon_pull_request Here is a summary of the changes 1) created and displayed an icon for Part_Export, same style as the existing Part_Import icon. 2) display the tree icon for Part_RuledSurface, I set it so that it shows the children shapes in the tree but does not auto-hide them. This makes Part_RuledSurface's behaviour consistent with Part_Mirror and different to for example Part_fuse. I made the code to auto hide the wrote a brief description and commented the code and description out, so that others can easy change this if they want to. Basically If you create a couple of lines then created the ruled surface, you could possibly expect it to auto-hide the Lines, however this is a real pain if you are selecting a sub-shape line off a shape (e.g. a box) as it would auto-hide the box. If you are making a shell from a series of ruled surfaces, using the edge of one as one of the edges of the next, you also do not want auto-hiding of the children shapes. 3) I change the auto name on creation, from "Filled_shape" to "Ruled_Surface" 4) switched over Part_Mirror's icon from the existing PNG icon to the existing SVG icon 5) flipped the direction of the import/export arrows to Werner's preference. link to pull request forum https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=17&t=3805 regards Jim | ||||
| 2013-03-25 07:35 | jmaustpc | New Issue | |
| 2013-03-25 07:35 | jmaustpc | Status | new => assigned |
| 2013-03-25 07:35 | jmaustpc | Assigned To | => yorik |
| 2013-03-25 13:33 | yorik | Note Added: 0003005 | |
| 2013-03-25 13:33 | yorik | Status | assigned => closed |
| 2013-03-25 13:33 | yorik | Resolution | open => fixed |
| 2013-03-25 13:33 | yorik | Fixed in Version | => 0.14 |
