| 0001075 | FreeCAD | Feature | public | 2013-04-01 05:04 | 2013-04-07 19:45 |
| Reporter | brnrd | Assigned To | yorik | ||
| Summary | 0001075: DWire Command Number Entry Improvement | ||||
| Description | The multi-point Draft Wire (DWire) command, in numeric entry mode, appears to require the visiting of all three fields before the [Enter] key completes a single point. One could complete the entry faster if entry in only a single field would be required to progress to the next point. This is most obvious in case where one works in the x-y plane where z is always 0. Of course duplicate points on top of each other should be prevented. I stumbled on this while working through the Basic_modeling_tutorial page. I noticed a lack of feedback in the tutorial because the points that one enters are outside the view. | ||||
Very good idea! The enter key should only hop through coordinates that are not greyed out. I'll implement that when I have a little time. |
Added in e167c9e Now pressing x, y or z while drawing immediately puts the UI in constrained mode, allowing for pretty fast input like: x 2 <enter> y 4 <enter> x -2 <enter> |
| 2013-04-01 05:04 | brnrd | New Issue | |
| 2013-04-01 12:10 | yorik | Status | new => assigned |
| 2013-04-01 12:10 | yorik | Assigned To | => yorik |
| 2013-04-01 12:11 | yorik | Note Added: 0003021 | |
| 2013-04-07 19:45 | yorik | Note Added: 0003051 | |
| 2013-04-07 19:45 | yorik | Status | assigned => closed |
| 2013-04-07 19:45 | yorik | Resolution | open => fixed |
| 2013-04-07 19:45 | yorik | Fixed in Version | => 0.14 |
