| 0001077 | FreeCAD | Bug | public | 2013-04-01 17:57 | 2013-04-03 11:23 |
| Reporter | brnrd | Assigned To | |||
| Summary | 0001077: Placement Panel not removed after Entity Deletion | ||||
| Description | What I do: - Create a Box solid, getting Box001 - Click on it in the Labels and Attributes panel - Click on the button with the ellipses to get the Placement panel - In the Labels and Attributes panel, click on Box001 and Delete Expected behavior: The Placement panel should be removed and I should be able to create a new box. Actual Behavior: The Part tool palette is disabled because the Placement panel is still active. Note: This is very confusing for beginners because there is no way to figure out why the workbench is disabled. | ||||
Actually, this problem would not exist if the Placement panel was a modal dialog where the user would not be able to delete the entity before closing the dialog. So the problem is that the Placement panel is not a modal dialog. |
Sorry, I am wrong - this can't be a dialog if other actions should be enabled while editing placement. |
The behaviour has changed that the placement panel doesn't cause to deactivate all the commands. So, you can still create new objects if you want while the panel is open. But note, the panel still won't be closed when deleting an object from the document. This is intended! |
git show 0d62206 |
| 2013-04-01 17:57 | brnrd | New Issue | |
| 2013-04-01 18:04 | brnrd | Note Added: 0003022 | |
| 2013-04-01 18:07 | brnrd | Note Added: 0003023 | |
| 2013-04-03 11:22 | wmayer | Note Added: 0003028 | |
| 2013-04-03 11:23 | wmayer | Note Added: 0003029 | |
| 2013-04-03 11:23 | wmayer | Status | new => closed |
| 2013-04-03 11:23 | wmayer | Resolution | open => fixed |
| 2013-04-03 11:23 | wmayer | Fixed in Version | => 0.14 |
