| 0000109 | FreeCAD | Feature | public | 2010-06-19 04:58 | 2010-06-21 08:53 |
| Reporter | Assigned To | wmayer | |||
| Summary | 0000109: wait coursor for open operation via python module | ||||
| Description | I integrate at the moment a long running python script for IDF import. Registered as python file ending handler to App. Would be good a wait cursor would be activated till the open operation. | ||||
since you don't like my fixes anyway, you can do it right by your self.... |
Use class FreeCAD.Base.ProgressIndicator start: Expects two parameters string (status text) and int (number of steps) next: One optional boolean argument. If this is True it is possible to abort a pending operation with ESC stop: Stops the current indicator. This method can be omitted but must be called before a second call of start() Note: When experimenting with this class in the GUI python console the application doesn't accept any further input. To leave this mode CTRL+ALT+ESC must be pressed. Example: import time def test(): s=App.Base.ProgressIndicator() s.start("www",100) for i in range(101): import time time.sleep(0.05) s.next(True) #s.stop() test() |
| 2010-06-19 04:58 |
New Issue | |
| 2010-06-19 04:58 |
Status | new => assigned |
| 2010-06-19 04:58 |
Assigned To | => wmayer |
| 2010-06-19 04:59 |
Note Added: 0000247 | |
| 2010-06-21 08:53 | wmayer | Note Added: 0000251 | |
| 2010-06-21 08:53 | wmayer | Status | assigned => closed |
| 2010-06-21 08:53 | wmayer | Resolution | open => fixed |
