0001091SketcherBugpublic2014-02-04 15:22
Reporterbrnrd Assigned Toyorik
Product Version0.13
Fixed in Version0.14
Summary0001091: Cannot create Polyline in Sketch
DescriptionHow I reproduce this:
- Start FreeCAD
- Open the attached file
- Select the Part Design Workbench
- In Project View, double-click on Sketch
- Select from toolbar "Create a plyline in the sketch"
- Set the first point at the right ent of the outer arc
- From this point, move the mouse down a little and then left
Expected result: The grey line extending from the first point should be between the first point and
the mouse cursor
Actual result: The line is constrained by the dimension line as can be seen in the attached screen shot.
Additional InformationWindows XP
PinRing.FCStd1 (2,879 bytes)
2013-04-09 06:12
yorik
2014-02-04 15:22
administrator   ~0004139
This is actually not a bug but a feature... Press M while drawing will cycle through the different polyline modes, allowing you to go free from the constraint.
2013-04-09 06:11 brnrd New Issue
2013-04-09 06:11 brnrd File Added: PinRing.FCStd1
2013-04-09 06:12 brnrd File Added: PolyLineSketch.gif
2013-05-13 12:43 wmayer Project FreeCAD => Sketcher
2014-02-04 15:22 yorik Note Added: 0004139
2014-02-04 15:22 yorik Status new => closed
2014-02-04 15:22 yorik Assigned To => yorik
2014-02-04 15:22 yorik Resolution open => no change required
2014-02-04 15:22 yorik Fixed in Version => 0.14
