| 0001092 | Draft | Bug | public | 2013-04-09 14:18 | 2013-06-25 12:43 |
| Summary | 0001092: Draft absolute coords should be relative to the WP | ||||
| Description | If the relative button is pressed, "forced" absolute units such as the first point of a line or rectangle should be relative to the WP. Thread at https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=3908&p=30727#p30727 | ||||
Just a suggestion, but when using a WP, should the labels of X,Y,Z be changed to something like X',Y' and Offset? Or L/R, Up/Down and In/Out? It is supposed to be 2D after all. When WP=none, X,Y,Z is clear and allows for '3D' drafting. |
Hm not sure it won't be more confusing than it is... Bu you are right anyway, something could be done to differentiate. Maybe local X / global X? |
Added with commit 7f21632 The draft X,Y,Z coordinates are now displayed as global, or local if the current working plane is different from the world axes. |
| 2013-04-09 14:18 | yorik | New Issue | |
| 2013-04-09 14:18 | yorik | Status | new => assigned |
| 2013-04-09 14:18 | yorik | Assigned To | => yorik |
| 2013-04-09 15:18 | wandererfan | Note Added: 0003056 | |
| 2013-04-09 16:06 | yorik | Note Added: 0003057 | |
| 2013-04-19 19:43 | yorik | Project | FreeCAD => Draft |
| 2013-06-25 12:43 | yorik | Note Added: 0003238 | |
| 2013-06-25 12:43 | yorik | Status | assigned => closed |
| 2013-06-25 12:43 | yorik | Resolution | open => fixed |
| 2013-06-25 12:43 | yorik | Fixed in Version | => 0.14 |
