| 0001100 | Draft | Bug | public | 2013-04-19 10:15 | 2013-12-20 21:22 |
| Reporter | dubstar-04 | Assigned To | yorik | ||
| Summary | 0001100: Draft snapping issue with rectangles | ||||
| Description | OS: Ubuntu 12.10 Platform: 64-bit Version: 0.13.2049 (Git) Branch: master Hash: 602bfe48cf39ad9b8ac02d7085d6439887145bc0 Python version: 2.7.3 Qt version: 4.8.3 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 I am experiencing a number of crashes that seem to be related to the snaps. step 1: Draw a 100 x 100 rectangle from 0,0 step 2: Fillet the rectangle (10mm) step 3: draw a line from the centre of the top to the centre of the bottom on clicking to confirm the centre snap for the second point of the line FreeCAD crashes. This issue is highly repeatable. | ||||
I can't reproduce this behaviour... for me it all seems to work fine >>> import Draft >>> pl = FreeCAD.Placement() >>> pl.Rotation.Q = (0.0,-0.0,-0.0,1.0) >>> pl.Base = FreeCAD.Vector(0.0,0.0,0.0) >>> Draft.makeRectangle(length=100.0,height=100.0,placement=pl,face=False,support=None) >>> FreeCAD.getDocument("Unnamed").getObject("Rectangle").FilletRadius = 1.00 >>> FreeCAD.getDocument("Unnamed").getObject("Rectangle").FilletRadius = 10.00 >>> import Draft >>> points=[FreeCAD.Vector(50.0,100.0,0.0),FreeCAD.Vector(50.0,0.0,0.0)] >>> Draft.makeWire(points,closed=False,face=False,support=FreeCAD.ActiveDocument.getObject("Rectangle")) Can you try launching freecad from a terminal, and paste here any error message that appears on the crash? |
I launched FreeCAD from terminal however no information is logged. Is there a command line option to generate verbose logging? I tried $freecad -v but that just give the version. Thanks. |
Try "freecad -l" then in your /home/user/.FreeCAD folder you'll find a log file |
I updated to the lastest git and launch FreeCAD from terminal: OS: Ubuntu 12.10 Platform: 64-bit Version: 0.13.2055 (Git) Branch: master Hash: 3511a807a30cf41909aaf12a1efe1db6c53db577 Python version: 2.7.3 Qt version: 4.8.3 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 sandal@Office:~$ freecad -l FreeCAD 0.13, Libs: 0.13R2055 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## matplotlib not found, Plot module will be disabled pycollada not found, collada support will be disabled. Draft workbench activated Pick first point: Pick opposite point: Pick first point: Pick next point: Segmentation fault (core dumped) |
Here is the full log: ?Msg: FreeCAD 0.13, Libs: 0.13R2055 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Time = Sat Apr 20 20:43:33 2013 Log: AppDataSkipVendor = true Log: AppHomePath = /usr/lib/freecad/ Log: AppIcon = freecad Log: BinPath = /usr/lib/freecad/bin/ Log: BuildRepositoryURL = git://git.code.sf.net/p/free-cad/code Log: BuildRevision = 2055 (Git) Log: BuildRevisionBranch = master Log: BuildRevisionDate = 2013/04/18 13:48:49 Log: BuildRevisionHash = 3511a807a30cf41909aaf12a1efe1db6c53db577 Log: BuildVersionMajor = 0 Log: BuildVersionMinor = 13 Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Debug = 0 Log: DocPath = /usr/lib/freecad/doc/ Log: ExeName = FreeCAD Log: ExeVendor = FreeCAD Log: ExeVersion = 0.13 Log: LoggingFile = 1 Log: LoggingFileName = /home/sandal/.FreeCAD/FreeCAD.log Log: MaintainerUrl = http://apps.sourceforge.net/mediawiki/free-cad/index.php?title=Main_Page Log: PATH = /usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games Log: PYTHONPATH = Log: PythonSearchPath = :/usr/bin/../lib/python2.7/:/usr/bin/../lib/python2.7/plat-linux2:/usr/bin/../lib/python2.7/lib-tk:/usr/bin/../lib/python2.7/lib-old:/usr/bin/../lib/python2.7/lib-dynload Log: RunMode = Gui Log: SplashAlignment = Bottom|Left Log: SplashInfoColor = #c8c8c8 Log: SplashScreen = freecadsplash Log: SplashTextColor = #ffffff Log: StartWorkbench = StartWorkbench Log: SystemParameter = /home/sandal/.FreeCAD/system.cfg Log: UserAppData = /home/sandal/.FreeCAD/ Log: UserHomePath = /home/sandal Log: UserParameter = /home/sandal/.FreeCAD/user.cfg Log: Verbose = Log: Create Application Log: Init: starting App::FreeCADInit.py Log: Init: Searching for modules... Log: Init: Initializing /usr/lib/freecad/Mod/Machining_Distortion... done Log: Init: Initializing /usr/lib/freecad/Mod/Sketcher... done Log: Init: Initializing /usr/lib/freecad/Mod/ReverseEngineering... done Log: Init: Initializing /usr/lib/freecad/Mod/Image... done Log: Init: Initializing /usr/lib/freecad/Mod/PartDesign... done Log: Init: Initializing /usr/lib/freecad/Mod/Ship(Init.py not found)... ignore Log: Init: Initializing /usr/lib/freecad/Mod/Plot(Init.py not found)... ignore Log: Init: Initializing /usr/lib/freecad/Mod/MeshPart... done Log: Init: Initializing /usr/lib/freecad/Mod/OpenSCAD... done Log: Init: Initializing /usr/lib/freecad/Mod/Start... done Log: Init: Initializing /usr/lib/freecad/Mod/Draft... done Log: Init: Initializing /usr/lib/freecad/Mod/Test... done Log: Init: Initializing /usr/lib/freecad/Mod/Import... done Log: Init: Initializing /usr/lib/freecad/Mod/Assembly... done Log: Init: Initializing /usr/lib/freecad/Mod/Complete... done Log: Init: Initializing /usr/lib/freecad/Mod/Web... done Log: Init: Initializing /usr/lib/freecad/Mod/Raytracing... done Log: Init: Initializing /usr/lib/freecad/Mod/Mesh... done Log: Init: Initializing /usr/lib/freecad/Mod/Part... done Log: Init: Initializing /usr/lib/freecad/Mod/Arch... done Log: Init: Initializing /usr/lib/freecad/Mod/Robot... done Log: Init: Initializing /usr/lib/freecad/Mod/Points... done Log: Init: Initializing /usr/lib/freecad/Mod/Idf... done Log: Init: Initializing /usr/lib/freecad/Mod/Inspection... done Log: Init: Initializing /usr/lib/freecad/Mod/Drawing... done Log: Using /usr/lib/freecad/Mod as module path! Log: System path after init: Log: /usr/lib/freecad/bin Log: /usr/lib/freecad/Mod/Machining_Distortion Log: /usr/lib/freecad/Mod/Sketcher Log: /usr/lib/freecad/Mod/ReverseEngineering Log: /usr/lib/freecad/Mod/Image Log: /usr/lib/freecad/Mod/PartDesign Log: /usr/lib/freecad/Mod/Ship Log: /usr/lib/freecad/Mod/Plot Log: /usr/lib/freecad/Mod/MeshPart Log: /usr/lib/freecad/Mod/OpenSCAD Log: /usr/lib/freecad/Mod/Start Log: /usr/lib/freecad/Mod/Draft Log: /usr/lib/freecad/Mod/Test Log: /usr/lib/freecad/Mod/Import Log: /usr/lib/freecad/Mod/Assembly Log: /usr/lib/freecad/Mod/Complete Log: /usr/lib/freecad/Mod/Web Log: /usr/lib/freecad/Mod/Raytracing Log: /usr/lib/freecad/Mod/Mesh Log: /usr/lib/freecad/Mod/Part Log: /usr/lib/freecad/Mod/Arch Log: /usr/lib/freecad/Mod/Robot Log: /usr/lib/freecad/Mod/Points Log: /usr/lib/freecad/Mod/Idf Log: /usr/lib/freecad/Mod/Inspection Log: /usr/lib/freecad/Mod/Drawing Log: /usr/lib/lightdm/lightdm Log: /usr/local/sbin Log: /usr/local/bin Log: /usr/sbin Log: /usr/bin Log: /sbin Log: /bin Log: /usr/games Log: /usr/local/games Log: Init: App::FreeCADInit.py done Log: Init: Creating Gui::Application and QApplication Log: OpenGL version 3.0 or higher is present Log: Init: Running FreeCADGuiInit.py start script... Log: Init: Searching modules... Log: Init: Initializing /usr/lib/freecad/Mod/Machining_Distortion... done Log: Init: Initializing /usr/lib/freecad/Mod/Sketcher... done Log: Init: Initializing /usr/lib/freecad/Mod/ReverseEngineering... done Log: Init: Initializing /usr/lib/freecad/Mod/Image... done Log: Init: Initializing /usr/lib/freecad/Mod/PartDesign... done Log: Init: Initializing /usr/lib/freecad/Mod/Ship... done Msg: matplotlib not found, Plot module will be disabled Log: Init: Initializing /usr/lib/freecad/Mod/Plot... done Log: Init: Initializing /usr/lib/freecad/Mod/MeshPart... done Log: Init: Initializing /usr/lib/freecad/Mod/OpenSCAD... done Log: Init: Initializing /usr/lib/freecad/Mod/Start... done Log: Init: Initializing /usr/lib/freecad/Mod/Draft... done Log: Init: Initializing /usr/lib/freecad/Mod/Test... done Log: Init: Initializing /usr/lib/freecad/Mod/Import... done Log: Init: Initializing /usr/lib/freecad/Mod/Assembly... done Log: Init: Initializing /usr/lib/freecad/Mod/Complete... done Log: Init: Initializing /usr/lib/freecad/Mod/Web... done Log: Init: Initializing /usr/lib/freecad/Mod/Raytracing... done Log: Init: Initializing /usr/lib/freecad/Mod/Mesh... done Log: Init: Initializing /usr/lib/freecad/Mod/Part... done Log: Loading Part module... done Msg: pycollada not found, collada support will be disabled. Log: Init: Initializing /usr/lib/freecad/Mod/Arch... done Log: Init: Initializing /usr/lib/freecad/Mod/Robot... done Log: Init: Initializing /usr/lib/freecad/Mod/Points... done Log: Init: Initializing /usr/lib/freecad/Mod/Idf(InitGui.py not found)... ignore Log: Init: Initializing /usr/lib/freecad/Mod/Inspection... done Log: Init: Initializing /usr/lib/freecad/Mod/Drawing... done Log: Init: Loading FreeCAD GUI Log: Init: Running FreeCADGuiInit.py start script... done Log: Init: Activating default workbench StartWorkbench Log: Loading GUI of Web module... done Log: Loading GUI of Start module... done Log: Loading Start module... done Log: [31mvoid DBusMenuExporterPrivate::addAction(QAction*, int)[0m: Already tracking action "Toggle visibility" under id 222 Log: Init: Showing main window Log: Main window restored Log: Show main window Log: Toolbars restored Log: Couldn't connect to spacenav daemon Log: Init: Entering event loop Log: Init: Processing command line files Log: Active view is Unnamed : 1 Log: Loading Draft module...done Msg: Draft workbench activated Msg: Pick first point: Msg: Pick opposite point: Msg: Log: Loading GUI of Part module... done Log: Sel : Clear selection Log: Sel : Add Selection "Unnamed.Rectangle.(null)(0.000000,0.000000,0.000000)" Msg: Pick first point: Msg: Pick next point: Log: Sel : Clear selection Log: Sel : Add Selection "Unnamed.Rectangle.Edge5(48.028969,100.000000,0.000000)" Msg: Log: Sel : Clear selection Log: Sel : Add Selection "Unnamed.Line.(null)(0.000000,0.000000,0.000000)" |
Is this issue still a problem with a recent version? I was never able to reproduce it... |
Closing because there is no more feedback on this issue. |
| 2013-04-19 10:15 | dubstar-04 | New Issue | |
| 2013-04-19 14:00 | yorik | Note Added: 0003077 | |
| 2013-04-19 14:02 | yorik | Status | new => assigned |
| 2013-04-19 14:02 | yorik | Assigned To | => yorik |
| 2013-04-19 14:17 | yorik | Status | assigned => feedback |
| 2013-04-19 15:07 | dubstar-04 | Note Added: 0003078 | |
| 2013-04-19 15:27 | yorik | Note Added: 0003079 | |
| 2013-04-19 19:22 | dubstar-04 | Note Added: 0003080 | |
| 2013-04-20 17:45 | dubstar-04 | Note Added: 0003088 | |
| 2013-07-05 22:11 | yorik | Project | FreeCAD => Draft |
| 2013-07-06 00:21 | yorik | Note Added: 0003333 | |
| 2013-12-20 21:22 | yorik | Note Added: 0003958 | |
| 2013-12-20 21:22 | yorik | Status | feedback => closed |
| 2013-12-20 21:22 | yorik | Resolution | open => fixed |
| 2013-12-20 21:22 | yorik | Fixed in Version | => 0.14 |
