0001101FreeCADBugpublic2013-06-27 11:47
Reporterdanielfalck Assigned Toyorik
Fixed in Version0.14
Summary0001101: seg fault Draft workbench when selecting Data Tab
Description"Segmentation fault (core dumped)" when selecting Data tab.
I noticed this when trying to look at the 'Data' Property tab with Draft mulit-point DraftWires and Draft dimensions.
I am up to date:
OS: Linux Mint 13 Maya
Platform: 64-bit
Version: 0.13.2056 (Git)
Hash: 051dee07f201df8c4cdfb0c74648fc6cdfe3d99c
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
yorik
2013-04-20 01:44
administrator   ~0003085
I can't reproduce that bug here, everything seems to work normally. Please give a precise step-by-step to make it happen? Maybe I'm doing something differently...
dubstar-04
2013-04-21 16:42
reporter   ~0003094
I can reproduce this everytime, however, I don't seem to be able to collect any useful logs.
Method:
1. start a new file
2. swith to draft workbench
3. draw a circle
4. draw a line
5. select an item in the tree
6. select the data tab (segmentation fault at this point)
FreeCAD log:
Msg: Draft workbench activated
Log: Active view is Unnamed : 1
  • (at 0x3799170)
  • Log: Active document is Unnamed (at 0x368d0a0)
    Msg: Pick center point:
    Msg: Pick radius:
    Log: Sel : Clear selection
    Msg: Log: Loading GUI of Part module... done
    Log: Sel : Add Selection "Unnamed.Circle.(null)(0.000000,0.000000,0.000000)"
    Log: Sel : Add Selection "Unnamed.Circle.Edge1(-0.346683,0.163049,0.000000)"
    Msg: Pick first point:
    Msg: Pick next point:
    Msg: Log: Sel : Clear selection
    Log: Sel : Add Selection "Unnamed.Line.(null)(0.000000,0.000000,0.000000)"
    Log: Sel : Add Selection "Unnamed.Circle.Edge1(-0.383904,0.635056,0.000000)"
    Terminal output:
    sandal@Office:~$ freecad -l
    FreeCAD 0.13, Libs: 0.13R2056 (Git)
    © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011
    matplotlib not found, Plot module will be disabled
    pycollada not found, collada support will be disabled.
    Pick center point:
    Pick radius:
    Pick first point:
    Pick next point:
    FreeCAD version:
    OS: Ubuntu 12.10
    Platform: 64-bit
    Qt version: 4.8.3
    Coin version: 3.1.3
    SoQt version: 1.5.0
    OCC version: 6.5.0
    yorik
    2013-04-21 19:58
    administrator   ~0003098
    That's very strange, no way I can make that bug happen here, all works fine... Can you check if it happens with the Arch and Part modules too?
    dubstar-04
    2013-04-24 14:22
    reporter   ~0003112
    I have tried to reproduce this issue on the part and draft bench, however it doesn't seem to affect them. Just the draft workbench.
    danielfalck
    2013-05-04 13:03
    reporter   ~0003134
    This seems to be fixed on my system now. Werner made a commit with the message: "Fix crash in property editor of property link is empty" - could this have been related?
    danielfalck
    2013-05-26 13:05
    reporter   ~0003182
    close this issue. thanks.
    yorik
    2013-06-27 11:47
    administrator   ~0003272
    Oops indeed forgot to close this one...
    2013-04-19 22:37 danielfalck New Issue
    2013-04-20 01:44 yorik Note Added: 0003085
    2013-04-20 01:45 yorik Status new => feedback
    2013-04-20 01:45 yorik Status feedback => assigned
    2013-04-20 01:45 yorik Assigned To => yorik
    2013-04-20 01:47 yorik Note Edited: 0003085
    2013-04-21 16:42 dubstar-04 Note Added: 0003094
    2013-04-21 19:58 yorik Note Added: 0003098
    2013-04-24 12:21 yorik Status assigned => feedback
    2013-04-24 14:22 dubstar-04 Note Added: 0003112
    2013-05-04 13:03 danielfalck Note Added: 0003134
    2013-05-26 13:05 danielfalck Note Added: 0003182
    2013-06-27 11:47 yorik Note Added: 0003272
    2013-06-27 11:47 yorik Status feedback => closed
    2013-06-27 11:47 yorik Resolution open => no change required
    2013-06-27 11:47 yorik Fixed in Version => 0.14
