| 0001103 | Draft | Feature | public | 2013-04-20 18:07 | 2014-01-01 16:45 |
| Summary | 0001103: Make a DWG importer/exporter based on the teigha convertor | ||||
| Description | The newly freely available multi-platform Teigha converter allows to make a script that imports and exports DWG files in freecad (converting them to/from a temp DXF file). The script will not include anything (for license compatibility reasons), but will simply check for the presence of the teigha executable on start, and activate DWG support if it is found. If not, a notice is displayed, like the collada import script. | ||||
The Teigha converter can be run from the command line: Command Line Format is: Quoted Input Folder Quoted Output Folder Output_version {"ACAD9","ACAD10","ACAD12", "ACAD13","ACAD14", "ACAD2000","ACAD2004", "ACAD2007","ACAD2010"} Output File type {"DWG","DXF","DXB"} Recurse Input Folder {"0","1"} Audit each file {"0","1"} [optional] Input file filter (default:"*.DWG;*.DXF") |
This works: TeighaFileConverter "/home/yorik" "/home/yorik" "ACAD2010" "DXF" "0" "1" "test.dwg" The second number (audit) needs to be 1 otherwise it fails |
Here is the url for the converter: http://www.opendesign.com/guestfiles/TeighaFileConverter |
Linux version already working with commit e3dd819 Help wanted! See http://forum.freecadweb.org/viewtopic.php?f=10&t=3965 |
From Teigha File Converter page: "DEB package: TeighaFileConverter_lnxX86_4.4dll_3.08.2_i386.deb Above installer was created for Linux Ubuntu 10.10 (x86 with 2.6 kernel)." Are these people aware that Ubuntu 10.10 has not been maintained since 12 months ago?!? Anyone tried installing it on a 64-bit system? |
On Windows XP the default installation path is C:\Program Files\ODA\Teigha File Converter 3.08.2\TeighaFileConverter.exe. The path is probably different on Windows Vista, Seven and 8. It is important to note that Windows users have the choice to change the install path. I have no idea how to use the Windows console. |
It installed fine on my debian 64bit... About the console, just search for "cmd" in the start panel, IIRC |
I know how to call a Windows console, what I'm saying is I have no idea what to do *in it*. The Unix/Linux syntax obviously does not work. My DOS days are a couple decades ago. |
OK found it. The problem is with spaces in the Windows console. The executable path needs to be put in brackets too for it to work: "C:\Program Files\ODA\Teigha File Converter 3.08.2\TeighaFileConverter.exe" "Path-To-Input-Directory" "Path-To-Output-Directory" "ACAD2010" "DXF" "0" "1" "Name-Of-A-Test-File.dwg" Notice that the paths use backslashes rather than slashes. Unfortunately the only DWG test file I have is massive, the resulting DXF is more than 8MB and FreeCAD chokes on it. It's good though, IĀ opened it in Teigha Viewer. |
Can you please help me, why doesnt that work then... C:\"Program Files (x86)"\ODA\"Teigha File Converter 3.09.0"\TeighaFileConverter "C:/test" "C:/test" "ACAD2010" "DXF" "0" "1" "22072-C32-00 RELEASE TESTER.dwg" I also tried without the file at the end, or with "*.DWG", or slashes, backslashes, many many other ways, whatever i do, it keeps popping the command line format window... Thank you !!! {"mmmm"} I need this command to work to retreive tons of parameters in tons of DWG files, , ill use the command in excel vba to fill tables. but the commmand doesnt work :*( |
Hm I should work further on this... I have no idea how to locate an executable on windows if it's not in a standard path. Maybe we can search for it in a standard location and add a preference setting so the user may set his own path... |
I just added in commit 47fd378 a preferences setting (Draft->Import options) to set the path to the TeighaFileConverter.exe utility manually. This should enable dwg import on non-linux systems. If you guys could test, I'd be grateful! |
I tried to open a .dxf on an XP system with these specs: Version 5.1 (Build 2600.xpsp_sp3_qfe.130704-0421 : Service Pack 3 And when I opened FreeCAD and tried to OPEN a .dxf file (Dafault = Part Workbench)this is what appeared in the report window from when I first launched FreeCAD: matplotlib not found, Plot module will be disabled pycollada not found, collada support will be disabled. downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfColorMap.py ... Download of dxf libraries failed. Please download them manually from https://github.com/yorikvanhavre/Draft-dxf-importerTraceback (most recent call last): File "<string>", line 1, in <module> File "C:\Program Files\FreeCAD0.13\Mod\Draft\importDXF.py", line 62, in <module> sys.exit() <type 'exceptions.SystemExit'>: <unknown exception data> Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> File "C:\Program Files\FreeCAD0.13\Mod\Draft\importDXF.py", line 62, in <module> sys.exit() I closed FreeCAD and started a new session of FreeCAD. Default workbench is still the Part Workbench. This time I select File -> New. (Unless I do File -> New, the option to select File -> Import is greyed out). Now I can select File -> Import a .dxf file and everything in my Report View is: matplotlib not found, Plot module will be disabled pycollada not found, collada support will be disabled. downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfColorMap.py ... Download of dxf libraries failed. Please download them manually from https://github.com/yorikvanhavre/Draft-dxf-importerTraceback (most recent call last): File "<string>", line 1, in <module> File "C:\Program Files\FreeCAD0.13\Mod\Draft\importDXF.py", line 62, in <module> sys.exit() <type 'exceptions.SystemExit'>: <unknown exception data> Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> File "C:\Program Files\FreeCAD0.13\Mod\Draft\importDXF.py", line 62, in <module> sys.exit() OS: Windows XP Platform: 32-bit Version: 0.14.2370 (Git) Branch: master Hash: a836759ebd91404954a778ff8885e152611576e1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 I'd like another user to confirm this behavior... |
I apologize, the hyperlinks above were created automatically; I only cut and pasted from the Report View window. My intention was for them to be posted simply as text. |
That problem is not related to the DWG importer. Please keep separate problems in separate topics... The message says what the problem is, the download of some libraries failed. Probably the server was down at the time you tried... Can you try again? |
Closing because it seems to be working ok now. Please reopen this topic if problems arise. |
| 2013-04-20 18:07 | yorik | New Issue | |
| 2013-04-20 18:07 | yorik | Status | new => assigned |
| 2013-04-20 18:07 | yorik | Assigned To | => yorik |
| 2013-04-20 18:19 | danielfalck | Note Added: 0003090 | |
| 2013-04-20 18:20 | danielfalck | Note Edited: 0003090 | |
| 2013-04-20 18:23 | yorik | Note Added: 0003091 | |
| 2013-04-20 18:23 | danielfalck | Note Edited: 0003090 | |
| 2013-04-20 18:39 | danielfalck | Note Added: 0003092 | |
| 2013-04-21 15:44 | yorik | Note Added: 0003093 | |
| 2013-04-21 15:57 | yorik | Note Edited: 0003093 | |
| 2013-04-21 19:32 | normandc | Note Added: 0003095 | |
| 2013-04-21 19:52 | normandc | Note Added: 0003096 | |
| 2013-04-21 19:56 | yorik | Note Added: 0003097 | |
| 2013-04-21 20:11 | normandc | Note Added: 0003099 | |
| 2013-04-21 20:35 | normandc | Note Added: 0003100 | |
| 2013-04-21 20:36 | normandc | Note Edited: 0003100 | |
| 2013-05-31 12:55 | shoyurbanana | Note Added: 0003186 | |
| 2013-05-31 12:56 | shoyurbanana | Note Edited: 0003186 | |
| 2013-05-31 12:58 | shoyurbanana | Note Edited: 0003186 | |
| 2013-05-31 15:13 | shoyurbanana | Note Edited: 0003186 | |
| 2013-07-05 22:11 | yorik | Project | FreeCAD => Draft |
| 2013-08-09 23:08 | yorik | Note Added: 0003446 | |
| 2013-08-24 19:50 | yorik | Note Added: 0003514 | |
| 2013-08-27 03:05 | bejant | Note Added: 0003522 | |
| 2013-08-27 03:08 | bejant | Note Added: 0003523 | |
| 2013-09-06 19:00 | yorik | Note Added: 0003558 | |
| 2013-09-06 19:00 | yorik | Status | assigned => feedback |
| 2013-09-06 19:02 | yorik | Note Edited: 0003558 | |
| 2013-12-20 21:21 | yorik | Note Added: 0003956 | |
| 2013-12-20 21:21 | yorik | Status | feedback => assigned |
| 2013-12-20 21:21 | yorik | Status | assigned => closed |
| 2013-12-20 21:21 | yorik | Resolution | open => fixed |
| 2013-12-20 21:21 | yorik | Fixed in Version | => 0.14 |
| 2014-01-01 16:42 | raulshc | Tag Attached: file format | |
| 2014-01-01 16:42 | raulshc | Tag Detached: file format |
