| 0001106 | FreeCAD | Bug | public | 2013-04-22 11:26 | 2013-05-13 12:36 |
| Reporter | rswarbrick | Assigned To | |||
| Summary | 0001106: Segfault when selecting a duplicate pad | ||||
| Description | When selecting the data panel and "Bracket Cut Pad 002" in the attached file, FreeCAD segfaults. I created a pad of a (very) simple sketch - a rectangle, in fact. Then used Edit/Duplicate Selection to create a couple of duplicates. The plan was then to offset them slightly unusually and then cut the lower bracket object by them. I haven't tried to debug this, but one possibility for the segfault is the naming scheme: I named the first object "Bracket Cut Pad 001". Maybe the code is looking for "Bracket Cut Pad" somewhere? | ||||
| related to | 0001111 | closed | PartDesign | Deleting sketch after padding was done crashes the program |
2013-04-22 11:26
further info: in the project tree, a double click on "Bracket Cut Pad 002" or "Bracket Cut Pad 003" fails. a double click on Bracket Cut Pad 001" brings up the Pad Parameters dialog in the Task panel. Modfiying "Bracket Cut Pad 002" pad length in Data tab of Property panel yields "No Sketch Linked" and a changed (red circle with lc "i"?) icon in the project tree. Pad length change is not reflected in model, but is reflected in Property. Moving "Bracket Cut Pad 002" by changing position in Data tab works, but also produces "No Sketch Linked". Should "Duplicate Selection" preserve link to underlying sketch? or produce a new duplicate sketch properly linked to "Bracket Cut Pad 002"? >>> EDIT: "Duplicate Selection" is a "simple copy" (non-parametric) so it isn't supposed to keep a link to the original. But if it is non-parametric, why are there parameters in Data tab? Should be just a dumb shape? OS: Ubuntu 12.04.2 LTS Platform: 64-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 |
This does not happen in Version: 0.13.2084 (Git). Also there is now a MessageBox for "input error no sketch linked". Problem solved? |
The report actually describes the same bug as in 0001111. The problem was that the Pad feature crashed if no sketch was linked to it. The old version of "Duplicate selection" (this has changed now) created copies with no links and thus the above happens. So, this bug is fixed now. |
| 2013-04-22 11:26 | rswarbrick | New Issue | |
| 2013-04-22 11:26 | rswarbrick | File Added: full-heatsink.fcstd | |
| 2013-04-23 10:35 | wandererfan | Note Added: 0003102 | |
| 2013-04-23 10:37 | wandererfan | Note Edited: 0003102 | |
| 2013-04-29 21:31 | wandererfan | Note Edited: 0003102 | |
| 2013-04-29 21:34 | wandererfan | Note Edited: 0003102 | |
| 2013-04-30 19:49 | wandererfan | Note Added: 0003128 | |
| 2013-05-13 12:35 | wmayer | Note Added: 0003150 | |
| 2013-05-13 12:35 | wmayer | Relationship added | related to 0001111 |
| 2013-05-13 12:36 | wmayer | Status | new => closed |
| 2013-05-13 12:36 | wmayer | Resolution | open => fixed |
| 2013-05-13 12:36 | wmayer | Fixed in Version | => 0.14 |
