| 0001112 | PartDesign | Bug | public | 2013-04-27 14:59 | 2014-03-09 10:29 |
| Reporter | project4 | Assigned To | wmayer | ||
| Summary | 0001112: Changing sketch size that contains arcs after padding will create an artifact on bottom side | ||||
| Description | Changing sketch size that contains arcs after padding will create an artifact on bottom side of the object (another arc?). The additional arc might be deleted, but those who don't know might not notice that. See the attached file. | ||||
| Steps To Reproduce | Create a sketch with 2 parallel lines of 60mm and 2 arcs on the sides, let say with radius of 15mm. Pad the sketch with 1mm height. I color the object to green since my parts are green (meccano parts), but I'm not sure it has anything to do with the problem, it just makes the artifact be visible. Go into sketch mode again and change the parallel lines length to 100mm. Close the task window and the padding will be updated to the new size. Roll the model to see it from the bottom and you'll notice the 2 additional arcs on top of the normal arc edges. | ||||
2013-04-27 14:59
Just figured it out that the "artifact" arc is actually the sketch layer that became visible after changing it's size, although in the tree view on the left it's shown as gray (I assume that's a non-visible state). It should not be deleted since it will delete the main sketch and cause other problem I've reported. The severity can be lowered to minor. The fix will be to leave the sketch in invisible state as it was before the change of the lines length. |
Well... Playing a bit more I'm not sure if it's a bug since as I can see now every sketch becomes visible after "OK" is pressed in the tasks window. I personally think that's not a logical behavior since I didn't ask it to become visible, I've only changed some parameters. In my object there are additional layers line padding, another sketch for holes and LinearPattern, so only the last one should be visible. |
OS: Ubuntu 11.10 Platform: 64-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.2+ Qt version: 4.7.4 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 |
| 2013-04-27 14:59 | project4 | New Issue | |
| 2013-04-27 14:59 | project4 | File Added: artifact.fcstd | |
| 2013-04-27 15:06 | project4 | Note Added: 0003114 | |
| 2013-04-27 15:11 | project4 | Note Added: 0003115 | |
| 2013-04-28 18:26 | project4 | Note Added: 0003125 | |
| 2014-03-09 10:29 | wmayer | Changeset attached | => FreeCAD Master master 947a030e |
| 2014-03-09 10:29 | wmayer | Assigned To | => wmayer |
| 2014-03-09 10:29 | wmayer | Status | new => closed |
| 2014-03-09 10:29 | wmayer | Resolution | open => fixed |
