| 0001114 | FreeCAD | Patch | public | 2013-04-27 18:43 | 2014-01-12 22:37 |
| Reporter | oosterkamp | Assigned To | yorik | ||
| Priority | normal | Severity | trivial | Reproducibility | N/A |
| Summary | 0001114: Teigha File Converter not found, DWG support will be disabled. | ||||
| Description | Hi Yorik, I have installed the latest Teigha file converter (http://www.opendesign.com/guestfiles/TeighaFileConverter). pulled the latest git version, compiled it cmake make. But when starting up Freecad the terminal output indicates:"Teigha File Converter not found, DWG support will be disabled" Opensuse 12.3 64bit. What Teigha version are you using? | ||||
| Additional Information | I am able to run Teigha as a stand-alone piece and it works (much better that the previous version) | ||||
Can probably closed |
Oops, yes, I had not seen that one... Looks very old, and since then I added a pref setting to manually specify the path to the teigha converter, which should solve things once and for all for all platforms. I'll close this issue, don't hesitate to reopen if needed. |
| 2013-04-27 18:43 | oosterkamp | New Issue | |
| 2014-01-12 17:50 |
Assigned To | => yorik |
| 2014-01-12 17:50 |
Status | new => assigned |
| 2014-01-12 17:50 |
Note Added: 0004053 | |
| 2014-01-12 22:36 | yorik | Note Added: 0004069 | |
| 2014-01-12 22:37 | yorik | Status | assigned => closed |
| 2014-01-12 22:37 | yorik | Resolution | open => fixed |
| 2014-01-12 22:37 | yorik | Fixed in Version | => 0.14 |
