| 0001115 | PartDesign | Bug | public | 2013-04-27 18:51 | 2015-01-08 05:30 |
| Reporter | project4 | Assigned To | jmaustpc | ||
| Summary | 0001115: Can't intuitively change value of a distance constraint | ||||
| Description | When you have a model with different layers and constraints indicating distance between points and you want to get back to the sketch view from the 3D view to change something... Double clicking on the value you want to change doesn't open the "insert datum" dialog as it would be expected, in fact the distance component doesn't become yellow as a currently selected object on the screen. In order to make it work I have to select something on the model first or make a selection operation around the value I want to change (I mean something like click somewhere above left of the value and drag it to bottom right while pressing on the mouse button). Only after that it's possible to change the value again. I think changing other parameters (like angle or radius) will behave the same, don't have anything open right now to check. | ||||
OS: Ubuntu 11.10 Platform: 64-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.2+ Qt version: 4.7.4 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 |
It does now, this has been fixed a long time ago. OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3703 (Git) Branch: FreeCAD-0-14 Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 |
This worked in 0.14.3703 release version. So must have been fixed at some point in the past. |
| 2013-04-27 18:51 | project4 | New Issue | |
| 2013-04-28 18:26 | project4 | Note Added: 0003123 | |
| 2015-01-08 05:26 | jmaustpc | Note Added: 0005574 | |
| 2015-01-08 05:28 | jmaustpc | Note Edited: 0005574 | |
| 2015-01-08 05:30 | jmaustpc | Note Added: 0005575 | |
| 2015-01-08 05:30 | jmaustpc | Status | new => closed |
| 2015-01-08 05:30 | jmaustpc | Assigned To | => jmaustpc |
| 2015-01-08 05:30 | jmaustpc | Resolution | open => fixed |
| 2015-01-08 05:30 | jmaustpc | Fixed in Version | => 0.14 |
