| 0001116 | PartDesign | Bug | public | 2013-04-28 18:15 | 2013-07-13 11:42 |
| Reporter | project4 | Assigned To | wmayer | ||
| Summary | 0001116: "Save as" to a file with a dot in the name will show the name only up to the dot | ||||
| Description | When "saving as" to a file that contains a dot (for example to indicate dimensions of the model for example), the program will show only the first part of the name (up to the dot) in the tree view on the left and in the tab on the bottom of the screen. Looks like the full file name is used correctly since save operation is done properly. Opening a file with dot in the name shows it properly in the program. I'm using Linux version of the program. | ||||
OS: Ubuntu 11.10 Platform: 64-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.2+ Qt version: 4.7.4 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 |
Confirmed for 0.13 but works with 0.14. |
Sorry for reopenning, but I couldn't find another way to ask the question: Where can I get the 0.14 version? I'm installing now the latest version from daily build PPA and it shows that the version is 0.13+git201305091330 |
Good point! The package version 0.13+git... is actually version 0.14. We have to adjust the Changlog files, too. Thanks for the hint! |
Ok. I've cloned the sources from git after that and saw that it appears as 0.14 there. Will stay on git versions for now. |
| 2013-04-28 18:15 | project4 | New Issue | |
| 2013-04-28 18:25 | project4 | Note Added: 0003122 | |
| 2013-07-01 11:05 | wmayer | Assigned To | => wmayer |
| 2013-07-01 11:05 | wmayer | Status | new => confirmed |
| 2013-07-01 15:22 | wmayer | Note Added: 0003316 | |
| 2013-07-01 15:22 | wmayer | Status | confirmed => closed |
| 2013-07-01 15:22 | wmayer | Resolution | open => fixed |
| 2013-07-01 15:22 | wmayer | Fixed in Version | => 0.14 |
| 2013-07-10 18:07 | project4 | Note Added: 0003376 | |
| 2013-07-10 18:07 | project4 | Status | closed => feedback |
| 2013-07-10 18:07 | project4 | Resolution | fixed => reopened |
| 2013-07-12 09:07 | wmayer | Note Added: 0003383 | |
| 2013-07-12 09:34 | project4 | Note Added: 0003384 | |
| 2013-07-13 11:42 | wmayer | Status | feedback => closed |
| 2013-07-13 11:42 | wmayer | Resolution | reopened => fixed |
