0001119FreeCADBugpublic2014-03-02 11:57
Reportertruesays Assigned To
Product Version0.13
Fixed in Version0.14
Summary0001119: Part Fusion Doesn't Work Correctly Between Fillet+Flat Part & Cylinder Part
DescriptionPart Fusion Doesn't Work Correctly Between Fillet+Flat Part & Cylinder Part
Check Attached file for example case.
this always happen on my Ubuntu Freecad 0.13
Fusion Error.fcstd (Attachment missing)
normandc
2013-05-16 02:49
manager   ~0003163
You should specify your exact Ubuntu version.
The file is incomplete. The objects that were used to create the current objects are missing from the file. Is that intended? We have no way of knowing how the current shapes were produced. It would help in figuring out what's going on.
From what I can see the problem is with Cut_Innr_Base. When intersecting a shape on the planar surface rather than the curved face it works, but not on the curved surface.
truesays
2013-05-16 03:13
reporter   ~0003165
Ubuntu 12.04 LTS Was used
Distributor ID: Ubuntu
Description: Ubuntu 12.04.2 LTS
Release: 12.04
Codename: precise
& x64 system
i will try to create simple example for this case.
Orginal file is too big & ugly for debuging
normandc
2013-05-16 03:28
manager   ~0003166
Complete FreeCAD version would be relevant too. There's a "Copy to clipboard" button in Help --> About FreeCAD.
truesays
2013-05-16 03:59
reporter   ~0003167
OS: Ubuntu 12.04.2 LTS
Platform: 64-bit
Version: 0.13.1830 (Git)
Branch: releases/FreeCAD-0-13
Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
 bugexample.fcstd [^] (900,395 bytes) 2013-05-16 06:00
check bugexample file's Fusion_Checkpoint1 & Fusion_CheckPoint2 's diff
something is wrong in there
think now i saved all in that file if other stuff is needed plz let me know
i really like Freecad so hope this kind of error doesn't exist.
2013-05-16 04:00
bugexample.fcstd (Attachment missing)
Jriegel
2013-06-26 13:23
administrator   ~0003257
Can reproduce.
Actually our CAD core fail on that, not much we can do about it.....
normandc
2013-06-26 23:15
manager   ~0003260
Maybe we should start reporting upstream, to Open Cascade bug tracker with these bugs? The same bugs have been there for years...
2014-03-02 11:57
administrator   ~0004350
Using OCC 6.6 this works properly now.
2013-05-02 00:10 truesays New Issue
2013-05-02 00:10 truesays File Added: Fusion Error.fcstd
2013-05-16 02:49 normandc Note Added: 0003163
2013-05-16 03:13 truesays Note Added: 0003165
2013-05-16 03:28 normandc Note Added: 0003166
2013-05-16 03:59 truesays Note Added: 0003167
2013-05-16 04:00 truesays File Added: bugexample.fcstd
2013-05-16 04:00 truesays Note Edited: 0003167
2013-06-26 13:23 Jriegel Note Added: 0003257
2013-06-26 13:23 Jriegel Status new => confirmed
2013-06-26 23:15 normandc Note Added: 0003260
2014-03-02 11:57 wmayer Note Added: 0004350
2014-03-02 11:57 wmayer Status confirmed => closed
2014-03-02 11:57 wmayer Resolution open => no change required
2014-03-02 11:57 wmayer Fixed in Version => 0.14
