| 0001129 | FreeCAD | Bug | public | 2013-05-10 07:47 | 2013-11-07 13:23 |
| Reporter | soaring38 | Assigned To | wmayer | ||
| Summary | 0001129: Application carsh on object deletion | ||||
| Description | in project view, application crash when i delete an object (pad or sketch) through the delete keyboard button, but deletion works with no crash when we go through the application menu Edit -> delete. | ||||
| Additional Information | Seems to be only on my linux laptop, note reprodce on my windows 7 I'm using Ubuntu 13.04 64-bit, freecad is updated through PPA, build version is 1830, publish date is 2/2/2013 at 18:09:17 My freecas windows build version is 1828 from january, installed trough binary installer on windows 7 64-bit | ||||
2013-05-10 07:47
Does it work now? A while ago there was implemented a workaround (because there is somehow a different behaviour of Qt) which solved also a crash when deleting an object. |
This is very likely fixed along with another ticket describing the same problem. |
| 2013-05-10 07:47 | soaring38 | New Issue | |
| 2013-05-10 07:47 | soaring38 | File Added: ExtruderV4.FCStd | |
| 2013-10-13 14:52 | wmayer | Note Added: 0003746 | |
| 2013-11-07 13:23 | wmayer | Note Added: 0003866 | |
| 2013-11-07 13:23 | wmayer | Status | new => closed |
| 2013-11-07 13:23 | wmayer | Assigned To | => wmayer |
| 2013-11-07 13:23 | wmayer | Resolution | open => no change required |
| 2013-11-07 13:23 | wmayer | Fixed in Version | => 0.14 |
