| 0001131 | Sketcher | Bug | public | 2013-05-13 06:37 | 2014-03-10 16:39 |
| Summary | 0001131: Crash when trying to edit sketch | ||||
| Description | http://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=4041 1. Open the project cover.fcstd 2. Run App.ActiveDocument.Sketch001.touch() 3. Recompute the document (takes a while) 4. This output is printed: >>> Exception (Mon May 13 10:23:44 2013): Not yet supported geometry for external geometry >>> Over-constrained sketch >>> Please remove at least one of the following constraints: >>> 44, 45, 46 5. Center button-meter-crossfader and Screw holes are marked as invalid 6. Try to edit sketch "Center button-meter-crossfader" ==> Crash The crash happens due to some asserts in the code of ViewProviderSketch. These are the lines: * 2411 assert(Constr->Second >= -extGeoCount && Constr->Second < intGeoCount); * 2517 assert(Constr->First >= -extGeoCount && Constr->First < intGeoCount); * 2518 assert(Constr->Second >= -extGeoCount && Constr->Second < intGeoCount); IMO in ViewProviderSketch "asserts" are heavily misused. Asserts are fine to check that something very obvious is wrong but definitely should not be used for error checking. I think all these asserts should be replaced with a proper exception handling. | ||||
See also: http://forum.freecadweb.org/viewtopic.php?f=3&t=4732&sid=f17656c9a111e196327a99bc7e66aa1b#p37185 |
The point is that rebuildExternalGeometry() has a reference to a non-supported geometry so that 'ExternalGeo' has not enough elements and thus is inconsistent to the number of external constraints. The solution is to remove all external constraints. |
| 2013-05-13 06:37 | wmayer | New Issue | |
| 2013-10-16 06:40 | wmayer | Note Added: 0003751 | |
| 2014-03-10 16:16 | wmayer | Note Added: 0004406 | |
| 2014-03-10 16:39 | wmayer | Changeset attached | => FreeCAD Master master b9f284cb |
| 2014-03-10 16:39 | wmayer | Assigned To | => wmayer |
| 2014-03-10 16:39 | wmayer | Status | new => closed |
| 2014-03-10 16:39 | wmayer | Resolution | open => fixed |
