| 0001132 | FreeCAD | Bug | public | 2013-05-17 11:06 | 2013-05-22 15:53 |
| Reporter | wandererfan | Assigned To | |||
| Summary | 0001132: 3x Print Functions Throws Exception | ||||
| Description | All 3 print functions(Print, Preview, ExportPDF) in the Std_File menu throw exceptions if invoked on the model view instead of a Drawing Page view. We should show a message asking user to select a Drawing page first? | ||||
| Additional Information | Exception (Fri May 17 08:16:38 2013): Offscreen rendering failed Exception (Fri May 17 08:24:30 2013): Offscreen rendering failed OS: Ubuntu 12.04.2 LTS Platform: 64-bit Version: 0.13.1830 (Git) Branch: releases/FreeCAD-0-13 Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
> Exception (Fri May 17 08:16:38 2013): Offscreen rendering failed > Exception (Fri May 17 08:24:30 2013): Offscreen rendering failed > We should show a message asking user to select a Drawing page first? No, this means that your graphic HW or driver doesn't support p-buffers. Try setting the environment variables: COIN_GLXGLUE_NO_PBUFFERS=1 COIN_GLXGLUE_NO_GLX13_PBUFFERS=1 and then restart FreeCAD. |
The environement variables allow successful printing, thanks. I also get a bunch of new messages that I don't really understand, but FC seems to work fine. Coin info in glglue_allow_newer_opengl(): Features of OpenGL version > 1.0 has been disabled, due to the use of a remote display. This is so because many common OpenGL drivers have problems in this regard. To force full OpenGL use, set the environment variable COIN_FULL_INDIRECT_RENDERING=1 and re-run the application. If you don't want this message displayed again, set the environment variable COIN_DONT_INFORM_INDIRECT_RENDERING=1. Coin warning in SoGLPolygonOffsetElement::updategl(): OpenGL driver doesn't support z-buffer offsetting |
| 2013-05-17 11:06 | wandererfan | New Issue | |
| 2013-05-21 10:17 | wmayer | Note Added: 0003172 | |
| 2013-05-21 11:42 | wandererfan | Note Added: 0003173 | |
| 2013-05-22 15:53 | wmayer | Status | new => closed |
| 2013-05-22 15:53 | wmayer | Resolution | open => no change required |
| 2013-05-22 15:53 | wmayer | Fixed in Version | => 0.14 |
