0001135File formatspublic2013-06-26 13:09
Reporterhazratsprut Assigned To
Summary0001135: Incorrect Export to IGS
Description1. Import attached STP file
2. Export model as IGS
3. Open IGS in any CAD system, model is incorrect
I checked it at SolidWorks 2006
cover_upper.stp (176,554 bytes)
2013-05-22 16:00
administrator   ~0003174
What is incorrect?
2013-05-23 02:51
FreeCADIGS.iges (1,013,356 bytes)
2013-05-23 02:51
hazratsprut
2013-05-23 02:55
reporter   ~0003175
Surfaces dissapear in the corners of model
I attach FreeCADandSW.jpg describing problem
2013-05-23 08:22
administrator   ~0003176
Hmm, the IGES loading with FreeCAD (or any other application that uses OpenCascade) is clearly correct. Why do you think that this must be a bug in FreeCAD (or OpenCascade respectively)? IMO this is rather a bug in SolidWorks.
Jriegel
2013-06-26 13:09
administrator   ~0003255
We can not fix bugs in SolidWorks
2013-05-22 03:26 hazratsprut New Issue
2013-05-22 03:26 hazratsprut File Added: cover_upper.stp
2013-05-22 16:00 wmayer Note Added: 0003174
2013-05-23 02:51 hazratsprut File Added: FreeCADIGS.iges
2013-05-23 02:51 hazratsprut File Added: FreeCADandSW.jpg
2013-05-23 02:55 hazratsprut Note Added: 0003175
2013-05-23 08:22 wmayer Note Added: 0003176
2013-06-26 13:09 Jriegel Note Added: 0003255
2013-06-26 13:09 Jriegel Status new => closed
2013-06-26 13:09 Jriegel Resolution open => no change required
