| 0001146 | FreeCAD | Bug | public | 2013-06-04 15:44 | 2013-07-01 09:35 |
| Reporter | stefanhgm | Assigned To | |||
| Summary | 0001146: Unable to export file to any file format | ||||
| Description | Hey everybody! I just started to work with freecad. After starting a first small project I tried to export it to different formats (svg,png...), but it did not work. So I started freecad from Terminal an I got the same always repeating error and the program is freezed. Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly. Usually this is a issue of opengl, but I did not find anything helpful in the web. I attached my project. Cheers! | ||||
2013-06-04 15:44
You cannot simply export any kind of objects to SVG or PNG. This works only for certain object types. For PNG you should use Tools > Save picture. For SVG you should either use the Drawing or Draft module or use the export filter "3D view" of the file dialog. The latter exports the whole scene of the 3d view into the SVG file. |
The first one ends with same error. When I use the "3D View" nothing happens at all, even when I select several elements. |
Info on operating system and FreeCAD version would be useful (if not mandatory). Go to Help --> About FreeCAD, there's a "copy to clipboard" button. Paste here. |
Most likely again a 3D driver issue.... |
This happened when not writing the file extension explicitly. This is solved now. |
| 2013-06-04 15:44 | stefanhgm | New Issue | |
| 2013-06-04 15:44 | stefanhgm | File Added: box.fcstd | |
| 2013-06-04 16:46 | wmayer | Note Added: 0003189 | |
| 2013-06-04 17:53 | stefanhgm | Note Added: 0003190 | |
| 2013-06-05 00:35 | normandc | Note Added: 0003191 | |
| 2013-06-26 10:29 |
Note Added: 0003247 | |
| 2013-07-01 09:35 | wmayer | Note Added: 0003305 | |
| 2013-07-01 09:35 | wmayer | Status | new => closed |
| 2013-07-01 09:35 | wmayer | Resolution | open => fixed |
| 2013-07-01 09:35 | wmayer | Fixed in Version | => 0.14 |
