| 0001164 | Draft | Feature | public | 2013-07-05 12:58 | 2013-12-20 21:15 |
| Summary | 0001164: Hatching | ||||
| Description | A way to define hatching, in the 3D scene as well as in the Drawing module. It is already possible in the Drawing module, by using an svg image as a <pattern> definition, to fill a closed area. The same svg image could be used, after transforming it into bitmap data with qt, to create a 2D texture to apply to 3D objects. We must still investigate if coin supports transparent textures, which would give state-of-the-art 2D hatching. | ||||
| 2013-07-05 12:58 | yorik | New Issue | |
| 2013-07-05 12:58 | yorik | Status | new => assigned |
| 2013-07-05 12:58 | yorik | Assigned To | => yorik |
| 2013-07-05 13:08 | yorik | Note Added: 0003332 | |
| 2013-07-05 22:11 | yorik | Project | FreeCAD => Draft |
| 2013-12-20 20:44 | yorik | Relationship added | related to 0001185 |
| 2013-12-20 21:15 | yorik | Changeset attached | => FreeCAD Master master bdb5eefd |
| 2013-12-20 21:15 | yorik | Status | assigned => closed |
| 2013-12-20 21:15 | yorik | Resolution | open => fixed |
