| 0001165 | Arch | Feature | public | 2013-07-05 22:16 | 2013-12-22 19:53 |
| Summary | 0001165: Arch Stairs | ||||
| Description | A stairs tool that allows to draw simple parametric stairs by defining a centerline or a sideline (similar to walls). The additional properties such as height, width, and number of degrees can then be set. By choosing an existing wire as centerline, one should also be able to draw curved stairs. | ||||
| 2013-07-05 22:16 | yorik | New Issue | |
| 2013-07-05 22:16 | yorik | Status | new => assigned |
| 2013-07-05 22:16 | yorik | Assigned To | => yorik |
| 2013-07-05 22:28 | yorik | Project | FreeCAD => Arch |
| 2013-12-22 19:53 | yorik | Note Added: 0003967 | |
| 2013-12-22 19:53 | yorik | Status | assigned => closed |
| 2013-12-22 19:53 | yorik | Resolution | open => fixed |
| 2013-12-22 19:53 | yorik | Fixed in Version | => 0.14 |
