| 0001167 | Arch | Feature | public | 2013-07-05 22:28 | 2013-07-07 12:37 |
| Summary | 0001167: Fixtures subsystem for Arch objects | ||||
| Description | A system that allows Arch objects to have additional pieces of objects attached to them, typically the metallic accessories of a window, such as latches, locks and hinges. These objects are needed there for completeness, and for future BIM properties such as calculating components quantities and prices. They have no geometrical influence. They should just be attached to the main geometry, and have no further part to play. Since these objects can also be fairly complex, they should probably be kept as meshes, but the system should accept shapes too. | ||||
| 2013-07-05 22:28 | yorik | New Issue | |
| 2013-07-05 22:28 | yorik | Status | new => assigned |
| 2013-07-05 22:28 | yorik | Assigned To | => yorik |
| 2013-07-05 22:28 | yorik | Project | FreeCAD => Arch |
| 2013-07-07 12:37 | yorik | Note Added: 0003350 | |
| 2013-07-07 12:37 | yorik | Status | assigned => closed |
| 2013-07-07 12:37 | yorik | Resolution | open => fixed |
| 2013-07-07 12:37 | yorik | Fixed in Version | => 0.14 |
