| 0001169 | FreeCAD | Feature | public | 2013-07-08 09:45 | 2015-01-08 06:47 |
| Reporter | wieszak | Assigned To | jmaustpc | ||
| Summary | 0001169: [PartDesign] "Boundary" tool | ||||
| Description | Something like pocket tool, only that extruded sketch is not substracted (so creating pocket), but intersected so in result part is "trimmed" to figure on sketch. | ||||
I have attached two images above, is this what you are wanting? A simple work around that I did in the above example is to create the desired sketch shape...the circle...then draw a rectangle around the circle. The result is a pocket is made from the difference between the circle and the rectangle...which produces the result you are looking for. I am not sure if this would be a good idea for a feature or not. This should be discussed on the Help forum, if it has not already been, and if there is a consensus that the tool would be a good idea then this ticket should be re-opened. |
Please discuss in the Help forums. |
| 2013-07-08 09:45 | wieszak | New Issue | |
| 2015-01-08 06:39 | jmaustpc | File Added: currentpocket.jpeg | |
| 2015-01-08 06:40 | jmaustpc | File Added: Partdesigncommonwouldproduce.jpeg | |
| 2015-01-08 06:46 | jmaustpc | Note Added: 0005580 | |
| 2015-01-08 06:47 | jmaustpc | Note Added: 0005581 | |
| 2015-01-08 06:47 | jmaustpc | Status | new => closed |
| 2015-01-08 06:47 | jmaustpc | Assigned To | => jmaustpc |
| 2015-01-08 06:47 | jmaustpc | Resolution | open => no change required |
