0001171FreeCADBugpublic2013-07-14 14:17
Reportercsanyi_pal Assigned To
Product Version0.13
Summary0001171: Can't build FreeCAD from GIT branch Raytracing
DescriptionHi,
On my Debian GNU/Linux unstable (sid) system I have downloaded the source:
FreeCAD Raytracing branch from GUT.
I used the command:
git://github.com/mrlukeparry/FreeCAD_sf_master.git
I just refresh my git repository with command:
git pull
After that I change directory to the build directory:
cd freecad-build
and run the command:
cmake DCMAKE_BUILD_TYPE=Debug PYTHON_INCLUDE_DIR = /usr/include/python2.7/ ../freecad
The output of this command follows:
-- The C compiler identification is GNU 4.8.1
-- The CXX compiler identification is GNU 4.8.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- The Fortran compiler identification is GNU
-- Detecting Fortran compiler ABI info
-- Detecting Fortran compiler ABI info - done
-- Checking whether /usr/bin/gfortran supports Fortran 90
-- Checking whether /usr/bin/gfortran supports Fortran 90 -- yes
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- Found PythonInterp: /usr/bin/python (found version "2.7.5")
-- Could NOT find PythonLibs (missing: PYTHON_INCLUDE_DIRS) (found suitable exact version "2.7.5+")
Python not found, install python!
-- Boost version: 1.49.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- signals
-- system
-- thread
-- Found Xerces-C: /usr/lib/libxerces-c.so
-- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.8")
CMake Warning at CMakeLists.txt:217 (find_package):
  By not providing "FindOCE.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "OCE", but
  CMake did not find one.
After that I tried to build it with command:
make -j2
Scanning dependencies of target soqt
Scanning dependencies of target coin
make[2]: *** make[2]: *** No rule to make target `/usr/lib/libSoQt.so', needed by `bin/pivy/gui/_soqt.so'No rule to make target `/usr/lib/libpython2.7.so', needed by `bin/pivy/_coin.so'. Stop.
make[2]: *** Waiting for unfinished jobs....
. Stop.
[ 0%] [ 1%] Building CXX object src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/coin_wrap.cpp.o
Building CXX object src/3rdParty/Pivy-0.5/CMakeFiles/soqt.dir/soqt_wrap.cpp.o
/home/csanyipal/CAD/FreeCAD/GIT_FreeCAD_branchRaytracing/freecad/src/3rdParty/Pivy-0.5/soqt_wrap.cpp: In function ‘PyObject* _wrap_delete_QWidget(PyObject*, PyObject*)’:
/home/csanyipal/CAD/FreeCAD/GIT_FreeCAD_branchRaytracing/freecad/src/3rdParty/Pivy-0.5/soqt_wrap.cpp:17377:10: warning: possible problem detected in invocation of delete operator: [enabled by default]
   delete arg1;
/home/csanyipal/CAD/FreeCAD/GIT_FreeCAD_branchRaytracing/freecad/src/3rdParty/Pivy-0.5/soqt_wrap.cpp:17336:12: warning: ‘arg1’ has incomplete type [enabled by default]
   QWidget *arg1 = (QWidget *) 0 ;
In file included from /usr/include/qt4/QtGui/qevent.h:45:0,
                 from /usr/include/Inventor/Qt/devices/SoQtDevice.h:39,
                 from /home/csanyipal/CAD/FreeCAD/GIT_FreeCAD_branchRaytracing/freecad/src/3rdParty/Pivy-0.5/soqt_wrap.cpp:3284:
/usr/include/qt4/QtGui/qwindowdefs.h:56:7: warning: forward declaration of ‘class QWidget’ [enabled by default]
 class QWidget;
/home/csanyipal/CAD/FreeCAD/GIT_FreeCAD_branchRaytracing/freecad/src/3rdParty/Pivy-0.5/soqt_wrap.cpp:17377:10: note: neither the destructor nor the class-specific operator delete will be called, even if they are declared when the class is defined
   delete arg1;
make[1]: *** [src/3rdParty/Pivy-0.5/CMakeFiles/soqt.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/all] Error 2
make: *** [all] Error 2
So what is the problem here and how can I solve it?
Regards, from Pal
csanyi_pal
2013-07-09 07:00
reporter   ~0003361
Oops, I lapse in one thing:
I used command to download the sources:
git clone git://github.com/mrlukeparry/FreeCAD_sf_master.git freecad
and not that command in my first post.
2013-07-09 07:33
administrator   ~0003362
On debian system there is an official pivy package available. So, in CMake configure you should disable to build pivy again.
Btw, you shouldn't open tickets on Mantis for git *branches* because this should be reserved for git *master* only. Instead open a topic in the phpBB forum.
2013-07-09 06:56 csanyi_pal New Issue
2013-07-09 07:00 csanyi_pal Note Added: 0003361
2013-07-09 07:33 wmayer Note Added: 0003362
2013-07-14 14:17 wmayer Status new => closed
2013-07-14 14:17 wmayer Resolution open => not fixable
