| 0001172 | FreeCAD | Bug | public | 2013-07-10 12:07 | 2014-03-10 23:26 |
| Reporter | rocketship | Assigned To | wmayer | ||
| Summary | 0001172: Installation should set Python path | ||||
| Description | Installer should either set correct Python path or place FreeCAD libraries within the existing Python path. When using FreeCAD libraries in Python outside of FreeCAD, they should automatically be found with "import FreeCAD". One of the sample scripts suggests manually setting the path to the FreeCAD libs at the beginning of the script, but this breaks cross-platform because the path is different. This should be invisible to the end user. Thanks! | ||||
| 2013-07-10 12:07 | rocketship | New Issue | |
| 2014-03-10 23:26 | wmayer | Changeset attached | => FreeCAD Master master 7176c0d9 |
| 2014-03-10 23:26 | wmayer | Status | new => closed |
| 2014-03-10 23:26 | wmayer | Assigned To | => wmayer |
| 2014-03-10 23:26 | wmayer | Resolution | open => fixed |
| 2014-03-10 23:26 | wmayer | Fixed in Version | => 0.14 |
