| 0001184 | Draft | Feature | public | 2013-07-16 16:59 | 2013-07-16 17:35 |
| Summary | 0001184: Support for arc segments in Draft Wires | ||||
| Description | Probably by adding another property which can hold arc data (center? third point?) of each edge | ||||
Done in 3a75c0e This was easier than I thought, Draft Wires can now be based on any sketch, even those with curves, by using the Upgrade tool on a Sketch object. The resulting object still keeps the sketch as a base, but has all the attributes of the Draft wire, such as being fillable with a pattern. |
| 2013-07-16 16:59 | yorik | New Issue | |
| 2013-07-16 16:59 | yorik | Status | new => assigned |
| 2013-07-16 16:59 | yorik | Assigned To | => yorik |
| 2013-07-16 16:59 | yorik | Project | FreeCAD => Draft |
| 2013-07-16 17:35 | yorik | Note Added: 0003414 | |
| 2013-07-16 17:35 | yorik | Status | assigned => closed |
| 2013-07-16 17:35 | yorik | Resolution | open => fixed |
| 2013-07-16 17:35 | yorik | Fixed in Version | => 0.14 |
