| 0001194 | FreeCAD | Feature | public | 2013-08-05 17:20 | 2013-10-11 21:22 |
| Summary | 0001194: Spreadsheet module | ||||
| Description | - Allow to use object properties in formulas (for example "=Objects.MyCube.Length") - Create a new "Spreadsheet Controller" object, that can be inserted as a child in a Spreadsheet object, and that controls the contents of a series of cells. For example, it could gather the Volume property of all objects in the scene - Import and export to some easy, basic formats (csv to start with, maybe others) | ||||
Have you tried to use gnumeric as spreadsheet for FreeCAD? Gnumeric can be extended with python. See here for example: https://projects.gnome.org/gnumeric/doc/sect-extending-python.shtml |
Using gnumeric inside freecad would be a very annoying and complex thing to maintain, especially on all the OSes supported by freecad. I prefer to concentrate on keeping a very simple spreadsheet module, and make it compatible/easy to sync with other spreadsheets... |
This is basically done, can be closed... |
| 2013-08-05 17:20 | yorik | New Issue | |
| 2013-08-05 17:20 | yorik | Status | new => assigned |
| 2013-08-05 17:20 | yorik | Assigned To | => yorik |
| 2013-08-07 06:29 | ulrich1a | Note Added: 0003440 | |
| 2013-08-07 11:33 | yorik | Note Added: 0003441 | |
| 2013-10-11 21:22 | yorik | Note Added: 0003733 | |
| 2013-10-11 21:22 | yorik | Status | assigned => closed |
| 2013-10-11 21:22 | yorik | Resolution | open => fixed |
| 2013-10-11 21:22 | yorik | Fixed in Version | => 0.14 |
